Fogged up headlights. Kind of a DIY
Old May 11, 2009 | 07:55 PM
sp00ledbseries's Avatar
Default Fogged up headlights. Kind of a DIY
So while my teg is down I decided to take the headlights out and see what I could do with them. I have seen the sanding and wax trick be for. But I am broke and dont have any of the stuff for it. So I seen what I had around the house. I had two rubbing compounds both turtle wax. The first was a their "regular" stuff. I also had the heavy duty. Well the regular sucked. I used the heavy duty and they came out great. My drivers side head you couldnt even see the "projector" in the low beam. So here is what I did and used
Rubbing compound
A old sock for rubbing
Damp rag for wiping them off
Dry rag for drying them off
I took the sock and got it wet and put the compound on it and started. used the wet rag and wiped it off to check it out. The dry rag to dry it off
My drivers side headlight had a crack in the housing so it had water inside. So I baked it in the oven to get the water out and clean the inside. I put it in for 10 minutes at 250 degrees. took it out and it came apart easily I don't have any before pics but if some one wants the after product ill take them.
Old May 11, 2009 | 08:42 PM
jhammond_82's Avatar
Reject Papi
Default Re: Fogged up headlights. Kind of a DIY
so does your head light still have a crack in it? or did you replace that one? if not, how did you repair the crack in the light?
Old May 11, 2009 | 08:53 PM
It had a small crack in the back of the housing not the cover. I used a little bit of silocone on it
donger
Lighting
33
Aug 20, 2010 09:37 AM
eight.o.eight.ltd
Jan 28, 2008 12:38 PM
I Like Hondas
Jul 5, 2006 11:16 AM
letsstophere
Jun 3, 2005 11:03 AM
TnEG2
Aug 22, 2003 12:31 AM
