B20 swap
I am swapping a b20b into my 90 crx dx. I am planning on using a p75 ecu. can i use the stock b20 intake manifold of do i have to use an integra manifold. One other question i have is i am using a hydro b16 tranny should i buy the clutch and flywheel for a b16 or b20 or does it matter. any help is appreciated.
flywheel does not matter, all b series will work. If you question is which OEM flywheel is lighter, i don't know.
for clutch the are the same tq rating. ITR clutch holds a tad bit more tq. Just get an exedy sport full disk clutch and be done with it.
Corksil
Jun 16, 2010 04:26 AM
