NO OIL In OIL FILTER??????
I dunno if anyone can help me or not, just recently got my car up and going, have about 6 low boost (25psi) passes on the motor. I have changed my oil probably 4 times, the first two times it was normal, when I took the filter off oil would come out. The last 2 times the filter did not have much oil in the filter at all and none spilt when the filter was taken off, I have never seen this. I went to a event last weekend and made a shake down run and on the return road I could here a little chatter, sounds like its coming from the bottom end, but checked all bearings and they are good. Going to do a leak down tomm, I am using a golden eagle filter adapter, wondering if anyone has delt with this before, this is some weird stuff going on. Oil pressure is good as well.
If you read the OP, he says he's getting oil pressure lol
If you happen to figure out the problem post what it was, never heard of this before. GL
i think its just draining back and the flaper valve is checking the rest, i usually dont get much spillage if the engine hasn't ran in hours or days. .
The filter brand you use (WIX) could have changed the desing and never told the public , personaly I would never run a wix filter , I use oem honda s2000 oil filters.
Depending on how long the car sat, and at what angle the engine sits in the car it drains back in.
I seen it many times with different cars and different filter.
IMO is nothing to worry about.
digdug18
30
Sep 13, 2005 05:12 PM
