Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Circuit Diagram - Fog Lights * Need help*
Old May 11, 2009 | 06:13 PM
frank358fr's Avatar
Default Circuit Diagram - Fog Lights * Need help*
Hi,
My fog lights stopped working so I check the manual shop of the Circuit Diagram. The problem is that I do not understand where the FOG LIGHT RELAY is on the vehicle because I think the relay is broken. Can someone show me...
Thank you
Frank
Old May 11, 2009 | 07:01 PM
byronl's Avatar
Default Re: Circuit Diagram - Fog Lights * Need help*
the foglight relay is underneath your lower dash, right above your knee bolster. The harness starts out with 2 wires going into the fuse box and goes to the relay and then finally to a 2-pin plug. Dunno if you understand me haha.
Old May 12, 2009 | 04:35 AM
ironworker's Avatar
Get a flashlight and take that black peice off under your dash. Lay on your back and look up it has its own spot in the middle or the the right of the middle while laying down.
Old May 12, 2009 | 07:42 AM
frank358fr's Avatar
Can someone take a picture of what you're taking about because I don't understand where you mean it is..
It will be very appreciated!
Old May 12, 2009 | 10:57 AM
ironworker's Avatar
i cant figure out how to upload the picture???? But i got saved in "my album" Thats my honda here is the link. https://honda-tech.com/album.php?alb...ictureid=24500 Its got a blue and white wire the relay is on top of the box, just pull that box off the clip and there it is.
Old May 12, 2009 | 08:52 PM
frank358fr's Avatar
Are you talking about the red circle I did?
Old May 12, 2009 | 10:18 PM
byronl's Avatar
yup, that's it
Old May 13, 2009 | 03:34 AM
ironworker's Avatar
dang howd you get the pic to upload? Yeah thats it..
Old May 13, 2009 | 06:36 AM
frank358fr's Avatar
Thanks,
How I did is upload the picture in Photobucket and take the link of the picture with IMG and copy past in the reply and your good to go :D
Old May 13, 2009 | 08:28 AM
ironworker's Avatar
Sweet thanks bro. Hopefully the pic helped you out.
Old May 13, 2009 | 03:22 PM
frank358fr's Avatar
You can please check the relay and can you confirm me that its 12V 40A.
Thanks
Old May 13, 2009 | 06:34 PM
ironworker's Avatar
Thanks
It doesnt say. My relay says "Mitsuba 7001 11 8715 Made In Vietnam". Honda part # 39794-SDA-A05. It cost 10-15 bucks for a new one.
Old May 14, 2009 | 09:47 AM
frank358fr's Avatar
Alright thanks bro,
I looked over my relay and I think it's not the same as yours. Can you confirm it.. and can you tell me what's the difference between our 2 relay. And can you tell me why I have a white wire not plug in..
Thanks
Pictures to help out!
Old May 14, 2009 | 10:42 AM
byronl's Avatar
im guessing that's an aftermarket fog light harness? When I did my install I plugged in the white/red and blue wires into the big white block connector that goes in the fuse box.
Old May 14, 2009 | 11:24 AM
frank358fr's Avatar
Its not suppose to be a aftermarket for lights harness but need folks to confirm it to me so I can spot the problem why my fog doesn't work anymore...
Old May 14, 2009 | 03:14 PM
ironworker's Avatar
lol Well theres your problem... that white wire is supposed to be pluged in above the fuse box. The 3 long things that have a bunch of wires going to it thats where it goes. You should have two wires that plug in to the middle of the 3 boxes.http://www.8thcivic.com/forums/light...-oem-fogs.html This DIY is for an 06 so its a little different than myne but it shows where to plug in the whitr/red and the blue wire in at. When you plug them in you should hear a click. You have to take the first one off and the second one off to. My relay is a little different.
Edit: By looking at the pictures you have a 06 si and i have a 07 which is different so that DIY should be money.
Old May 14, 2009 | 06:33 PM
ironworker's Avatar
BTW how did your foglights work before if that wire wasnt pluged in? Also after you plug everything in if they still dont work,replace the relay, check the fuse in the #6 spot 20amp, double check your grounds, and connections. Turn your wheel all the way to the left and pull back your left fender well lineing(standing in front of your car the left side) and double check that connection, make sure its all the way in because in 3 years its got alot of road grime in it, its hard to get a good connection.
Old May 16, 2009 | 08:35 PM
frank358fr's Avatar
I looked over my connection on the front fender and everything is fine.
The amp 20A was not there before my fog lights stopped working. I don't know if its one of the cause but I notice it. Its weird that my harness not OEM but I think the relay is broken. I will check this out tomorrow and let you know.
Thanks!
Old May 17, 2009 | 06:57 AM
frank358fr's Avatar
Hi,
I'm looking to get the wiring harness for the fog lights. I already have the fog lights, I just need the wiring harness since my harness are aftermarket and something is wrong with it, I want the OEM one. I looked over many website and auto parts but still find nothing. If someone can help me, I will be very appreciated.
Thanks
Old May 17, 2009 | 02:36 PM
frank358fr's Avatar
Everything works now thanks iron!
Old May 20, 2009 | 05:30 AM
084DRSi's Avatar
New User
What was the issue?
Old May 20, 2009 | 06:10 AM
frank358fr's Avatar
It was my White/red wire. It was unplug and it suppose to be plug in the fuse box. You can see the wire on one of my pictures I posted!
mike11
18
Jul 21, 2011 07:22 PM
jiro
Jun 24, 2009 09:11 AM
EK_kidd
24
Oct 13, 2008 01:24 PM
NorthernXposure
Aug 30, 2006 05:29 AM
92wraith
Oct 12, 2005 06:31 PM
