k series swap
Old May 11, 2009 | 04:30 PM
jfrase06's Avatar
Default k series swap
alright, well i just bought a totalled acura rsx-type s and i want to swap it into my honda civic dx year 2000, i just wanna know what its gunna run me, i am not putting it in,i think i'm going to be haveing evans tuning in PA do it, but i havent contacted them yet, i just want a price and what i'm going to need to buy to have it put in?!?!?!?
Old May 11, 2009 | 04:32 PM
iwanttokillgod's Avatar
Default Re: k series swap
$1000000000000000000000000000000 do some god damn research
Old May 11, 2009 | 04:38 PM
BryanM.'s Avatar
Resident Gearhead
Call them and ask.
Old May 11, 2009 | 04:57 PM
ekb16's Avatar
k20a.org
Old May 11, 2009 | 05:01 PM
eros18's Avatar
Depends on which shop you go.
If you have all the parts needed, then they will charge you for labor.
Call the shop you mentioned to get an exact estimate for the swap. That's the best way.
Old May 11, 2009 | 05:34 PM
blueg6's Avatar
Originally Posted by mcvtec
Call them and ask.
-__________________________________________________ _________________-
Old May 11, 2009 | 05:45 PM
turbo97coupe's Avatar
you have the expensive parts, the motor ,harness,trans,ecu, all the acces. shifter box , shifter cables. all the sensors . so it would be super cheap swap if you went outside and got your hands dirty . swaps are easy and it never hurts to jam more info and know how into your brain but you want a shop to do it and shops rates are expensive in my opinion it varys what the shop charges hourly wise, your still going to need swap axles , swap mounts ,engine managment and all the other little odds and ends but you should be able to part out the rest of the RSX and use that money for the swap and break even . goodluck with it man
Old May 11, 2009 | 05:47 PM
fizik's Avatar
You're gonna be looking a couple grand. Mounts, K-Pro, custom wiring harness, axles thats about $2,000 alone right there. I don't know if you can use the RSX shifterbox or if you have to buy a custom one but that's another item to tack onto your list if it is.
Old May 11, 2009 | 05:56 PM
cleansi's Avatar
you dnt need a custom shifter well depends what you mean by custom .
the k series uses cable linkage you need to make a mounting plate where your shift linkage used to be
Old May 11, 2009 | 05:58 PM
you use the OEM K box with a product like the Karcepts kit
dc_jdm_dreams
Oct 8, 2022 10:26 AM
1.8EG-T
Feb 7, 2015 03:44 PM
95Sol99civic
Dec 11, 2009 05:50 PM
w1Lbur
May 19, 2007 12:31 PM
ck123
30
Sep 6, 2006 07:47 PM
