matching IM to 68mm TB
Old May 11, 2009 | 12:44 PM
EJ1B18c's Avatar
Default matching IM to 68mm TB
I purchased an omni power 70mm tapered TB. i have a skunk2 Intake manifold. I need to know how all you guys are machining/making the IM 68 or 70mm. FYI i called around my area and no one seems to be able to do it. what machine is involved?
Old May 11, 2009 | 12:54 PM
Turbogixxer's Avatar
Default Re: matching IM to 68mm TB
70mm
Old May 11, 2009 | 12:59 PM
EJ1B18c's Avatar
what does that mean?
do you mean to bring the manifold to 70mm creating a small wall/lip to somehow effect the flow in the opposite direction?
Old May 11, 2009 | 01:01 PM
bore the manifold to 70mm
Old May 11, 2009 | 01:04 PM
EJ1B18c's Avatar
Ok but my prob is where? Is there anyway of doing this diy without messing it up. Im looking for the method used in boring to 70mm
Old May 11, 2009 | 03:54 PM
turboedsupe's Avatar
Just put the gasket on the im and trace the outline with a marker. Then bore it out with a air powered grinder. It doesnt have to be perfect but its real easy to do yourself
Old May 12, 2009 | 03:52 AM
EJ1B18c's Avatar
ok thanks ill give it a go.
Old May 12, 2009 | 05:06 AM
jhammond_82's Avatar
Reject Papi
it's always nice to have a junk manifold handy to practice on i would think. that way, if you do screw it up, your not out 250 bucks on it, just my 2 cents.
Old May 12, 2009 | 07:02 AM
EJ1B18c's Avatar
good idea i think i still have my old SIR one lying about.
thakid
Jun 22, 2012 06:52 PM
BlackCivicEX
May 24, 2011 11:39 AM
gezzuzz
Apr 13, 2008 07:40 PM
K2sInteg98
Feb 21, 2007 04:03 PM
athoughts
Feb 23, 2005 08:00 AM
