Low Idle Problem?????
i have a 94 integra 4dr just got it was always in to 4dr ef civics but now just got a dc 4dr well enoght of that when i 1st got the car it ran fine just had an exhaust leak but got that fixed...then 1 week later my car starts to idle funny only when still like drive while on the brake ,or in park nd reverse and so on the idle drops so low and slow then pops back up then lowers again like wanting to turn off then go up like sputtering any 1 noe wat the problem is thanks in advance
Could be! get a volt meter set it at 20vdc probe the middle wire of the tps plug with the red probe and the black to your - batery terminal, put the key to the start position but dont start the car! check voltage it should be .50 and then when you manually open the throtle to WOT it should read 4.5 now if thats on point then leave it if not you must remove it from its rivits and install 2 small bolts and calibrate it until its within spec. if its in spec then look at your iacv its behind the intake manifold check for pinched wires in the plug or take the 2 12mm bolts out and clean it with carb cleaner theres also a screan you can replace if its cloged or too dirty. if it still does it then check for a vacume leak in any vacume line start from the fuel pressure regulator, then report back.
4tika4
Apr 19, 2009 09:43 AM
