evap vacuum question
Old May 11, 2009 | 11:56 AM
94-integra-ls's Avatar
Default evap vacuum question
i want to get ride of the evap canister #1 and i need to know what to do with the lines going from the canister to the manifold #2 and #3 can these lines just be plugged or do they need to be routed to a different location. all help will be greatly appricated
Old May 11, 2009 | 12:00 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Default Re: evap vacuum question
Where'd you find that, I want to eliminate mine as well on a 00 gsr?
Old May 11, 2009 | 12:23 PM
racebum's Avatar
why do you guys want to get rid of it? all it does is let the gas tank vent into the manifold. nothing more
Old May 12, 2009 | 10:43 AM
i am not running the stock fuel filter i am running an inline fuel filter and i dont like the look of it in my bay and i dont want it in a clean looking bay i have worked so hard on
Old May 12, 2009 | 12:05 PM
Dynasty21's Avatar
Old May 12, 2009 | 12:14 PM
racebum's Avatar
you guys will need a chipped ecu with this turned off or you'll get a code. then, basically you just remove it and plug the vacuum on the manifold. you might want to run the fuel tank vent somewhere under the car or you will get a lovely gas odor under the hood on hot days.
Old May 12, 2009 | 07:03 PM
i dont remember where i got it i searched evap canister or something like that and i found one for a gsr and one for a ls and i have i will have it all worked out when i get my car tuned it has a hondata s200 with boost options
Old May 14, 2009 | 10:24 PM
Dynasty21's Avatar
zkelley
Dec 29, 2007 08:04 PM
Eg_TypeR
Feb 23, 2007 04:48 PM
garyc17
May 17, 2006 07:20 AM
the0ne
Dec 10, 2004 06:20 PM
chrisb
10
May 16, 2003 12:55 AM
