Honda S2000 Honda S2000
"Squealing" sound when clutch is not pushed in
Old May 11, 2009 | 10:41 AM
illi Adik's Avatar
Icon6 "Squealing" sound when clutch is not pushed in
In the last month or so my car has developed a squealing sound when the clutch pedal is not pushed in. I've noticed when sitting in traffic in neutral with the window down. As soon as I press the clutch pedal in the squealing sound goes away. At first I thought it was the throwout bearing but to my knowledge the throwout bearing will make noise when the pedal is pushed in correct?
FYI: 2005 Honda S2000 with ~ 45k on it. Original clutch.
Any insight would be much appreciated.
Joe
Old May 11, 2009 | 12:56 PM
A_ALCHAAR's Avatar
Default Re: "Squealing" sound when clutch is not pushed in
I would say its the throwout bearing. It makes noise when the clutch is NOT pressed.
Old May 11, 2009 | 02:53 PM
S2KFTW's Avatar
throw out bearing or the bearing in the flywheel, either way you have to drop the tranny might as well put a new clutch in at the same time, it's not too bad of a job.
Old May 11, 2009 | 05:02 PM
THE BULL's Avatar
def the throwout bearing
Old May 11, 2009 | 07:24 PM
illi Adik's Avatar
Any reason the throwout bearing would go? What am I looking at long term if I don't replace it right away? The clutch still engages and functions perfectly.
Not sure if this is a common occurrence.
redman223
Mar 1, 2024 01:55 PM
Nataku
Sep 18, 2010 06:22 PM
04civicex84
Honda Civic (2001 - 2005)
Nov 13, 2008 02:44 PM
Aron Parsons
Mar 6, 2006 09:18 PM
s2kkk
Honda S2000
14
Jan 28, 2006 07:54 PM
