B series rear mount bracket
Old May 11, 2009 | 09:02 AM
88 EF Hatch's Avatar
Default B series rear mount bracket
Alright so can I use stock rear mount bracket to swap obd0 ls into my ef or do I have to buy hasport? can I use any other oem rear bracket? like eg or DA bracket?
Old May 11, 2009 | 09:25 AM
big-guy 585's Avatar
Default Re: B series rear mount bracket
you can use the the t bracket for them 90-91 acura intagra bracket
Old May 11, 2009 | 10:30 AM
mjfubar101's Avatar
answer ^
Old May 11, 2009 | 10:39 AM
iwanttokillgod's Avatar
actually 90-93
Old May 11, 2009 | 10:49 AM
JScott3d's Avatar
I was going to say 90-93 also because I am running a 93 on mine
Old May 12, 2009 | 10:56 AM
xpwex's Avatar
Does it matter on Auto or 5 Speed?
Old May 12, 2009 | 04:02 PM
sawedoffcoupe's Avatar
im doing the same swap into my girlfriends 91 si, we got the hasport mounts, im not sure which other mounts to use, people always say "use the stock ones" so would that be the stock civic or stock integra mounts?
Old May 12, 2009 | 05:14 PM
0ne-Cam's Avatar
I tried to use my stock mounts but with the rear mounting bracket it doesn't fit because the rear mount is too far to the left and they dont align. I had to buy hasport mounts and move the rear mount towards the right. 4 holes are in the back support, 3 bolts hold the stock mount, new mount has only 2 bolts, you will have to move it towards the right. If tech knows what Im talking about thats great, if not I can take some pictures of how I did my swap.
Old May 12, 2009 | 08:20 PM
u cant use the stock mount in that year that rule only applys in the 92 honde civics and up with the 94 acura ls and up
Old May 12, 2009 | 08:53 PM
D16SiHatch's Avatar
yes, it must be from a manual trans
Old May 13, 2009 | 06:42 AM
So I have 3 innovative mounts and one hasport t bracket. Is that gonnal work?
Old May 13, 2009 | 10:39 AM
mjfubar101's Avatar
**** it should at least I would hope so...
slowboyy06
Sep 4, 2009 07:57 PM
Hatchd
Jun 22, 2005 04:00 PM
86si
Jan 2, 2005 03:20 PM
nicknasty
Nov 3, 2003 12:54 AM
delacampos
Jan 27, 2003 06:22 AM
