Broken wheel studs
my prelude is a 93 and I'm not sure how I should replace 2 wheel studs. I really don't want to press the hub off and have to buy a new bearing but I don't see anyway around it. does anyne have experience witht his?
No pressing needed
Are they front or rear studs? Both can be hammered out and pulled back in with nuts, but the fronts have less space to work with.
It is definitely possible, but you may have to grind a bit from the front of the knuckle. I have installed extended studs in the front and it just took some grinding, should be much less for a stock length stud.
It's a lot easier than the alternative
just curious...what symptoms are you noticing that are making you want to replace them?? is it a "clicking noise" up there? think i will soon be doing the same thing on the nissan family car.
no symptoms. i was missing 1 since i had bought the car and when i went to take the wheel off 1 other was seized on there so i broke that one too. so i only have 2 outa 4 now and since i'm swapping motors this is a good time to get it done.
I bet people are tired of seeing my post this picture by now, but here is the area I had to grind to install the extended studs if it helps:
You won't have to do near as much for normal studs. Those rotary tool attachments that are a cylinder shape or sandpaper work great
Please do explain how this is the 'shittiest' way to do and what is the 'rite' way. Taking all your suspension apart so you can put the hub in a press? No need for that.....
you think when you sell your car, if you ever do, someone is gonna be stoked to see that ****?
its just lazy and half assed honestly. do it rite or dont do it at all.
just my 2 cents..
'Rite' is not a word, but certainly there is nothing wrong with adding your 2 cents
a little grinding definitly did the trick... very simple to get them in/out after that.
ill be damned sure is! totally missed that. running on 18 of being awake...Im all for cost effective time saving work but grinding on the knuckle really urks me :/ How do you know the grinding of the knuckle does not affect it?
