Turbo Del Sol Dyno numbers
Old May 11, 2009 | 07:23 AM
GSE980's Avatar
Icon3 Turbo Del Sol Dyno numbers
So after much trouble shooting and four years of work 3 deployments to the gulf I finally hitched my car and got it up to Long Beach 300 Quay Ave Church Automotive
First off my I would just like to say that Shawn Church gets a 10/10 his knowledge and service were top notch. Him and his staff helped me out so much with my injectors leaking ECU shutting off on the dyno. I was stressin the hell out because when I intially put the GSR on the dyno for a basemap 3 years ago I put out only 60whp!
Forged internals
Aebs sleeves .5 over
port and polish
t3/t4 50. trim turbonectics
tial 38mm
walboro 255
800cc needles
NGK cords
Greddy profec B spec 2 boost controller
Hondata s300
omni 4 bar map
problems: spark plugs gapped to far. They are NGK Vpower 8's what would be a good gapping size for a 400 hp application.
FPR took a dump on us so we had to stop tuning......B&M......Im going to go with a stock FPR how much are they good for any good subsitutes.
My piston compression is to low 8:5 :1 ross pistons should of went with 9:1 so losing hp thats my fault when I was shopping.
My stupid ECU kept resetting it self the guy who sold me the S300 had a bent component which under load would heat up and turn the ECU off... Shawn caught this and fixed it problem solved.
278whp
242lbs. torque
@ 14 psi
Things I need to fix......before I finish my tune
-Spark plugs closer gapped 2...????????
-turbo inlet no intake or filter too much hot air.....
-Vtec wiring messed up had to actuate vtec maunally on dyno.
-new FPR either stock or something else???? any ideas ????
-mount resistor box for injectors
-take off painters lol tape for injector harness and use shrink tape.
-weld dump tube from wastegate to exhaust shawn said there was a exhaust leak somewhere and had to go with my wideband instead of his at the exhaust which was another loss in horsepower.
pics to come soon
Old May 11, 2009 | 07:28 AM
E85B18's Avatar
Default Re: Turbo Del Sol Dyno numbers
In for pics. Not a bad start, you'll be making more power soon! Ive got an AEBS block .5 over as well. Good ****!
Old May 11, 2009 | 01:56 PM
GSE980's Avatar
soo hears the pics when i first started the project in 05 but had to put it on hold 3 times because of the stupid skinnes blowing **** up
Old May 11, 2009 | 02:05 PM
GSE980's Avatar
and the rest
Old May 11, 2009 | 05:21 PM
GSE980's Avatar
what numbers are you putting up with it?
umair
16
Feb 21, 2009 05:40 PM
GSE980
Jul 1, 2006 01:48 PM
Ty.
Apr 2, 2004 08:11 PM
Slammd Sol
Jul 23, 2003 02:15 PM
BoostedD15B7
May 8, 2003 09:04 AM
