Turbo Del Sol Dyno numbers
So after much trouble shooting and four years of work 3 deployments to the gulf I finally hitched my car and got it up to Long Beach 300 Quay Ave Church Automotive
First off my I would just like to say that Shawn Church gets a 10/10 his knowledge and service were top notch. Him and his staff helped me out so much with my injectors leaking ECU shutting off on the dyno. I was stressin the hell out because when I intially put the GSR on the dyno for a basemap 3 years ago I put out only 60whp!
Forged internals
Aebs sleeves .5 over
port and polish
t3/t4 50. trim turbonectics
tial 38mm
walboro 255
800cc needles
NGK cords
Greddy profec B spec 2 boost controller
Hondata s300
omni 4 bar map
problems: spark plugs gapped to far. They are NGK Vpower 8's what would be a good gapping size for a 400 hp application.
FPR took a dump on us so we had to stop tuning......B&M......Im going to go with a stock FPR how much are they good for any good subsitutes.
My piston compression is to low 8:5 :1 ross pistons should of went with 9:1 so losing hp thats my fault when I was shopping.
My stupid ECU kept resetting it self the guy who sold me the S300 had a bent component which under load would heat up and turn the ECU off... Shawn caught this and fixed it problem solved.
278whp
242lbs. torque
@ 14 psi
Things I need to fix......before I finish my tune
-Spark plugs closer gapped 2...????????
-turbo inlet no intake or filter too much hot air.....
-Vtec wiring messed up had to actuate vtec maunally on dyno.
-new FPR either stock or something else???? any ideas ????
-mount resistor box for injectors
-take off painters lol tape for injector harness and use shrink tape.
-weld dump tube from wastegate to exhaust shawn said there was a exhaust leak somewhere and had to go with my wideband instead of his at the exhaust which was another loss in horsepower.
pics to come soon
Forged internals
port and polish
tial 38mm
walboro 255
800cc needles
NGK cords
Hondata s300
omni 4 bar map
278whp
242lbs. torque
@ 14 psi
pics to come soon
Re: Turbo Del Sol Dyno numbers
soo hears the pics when i first started the project in 05 but had to put it on hold 3 times because of the stupid skinnes blowing **** up
umair
16
02-21-2009 05:40 PM
