distributor problem
Old May 10, 2009 | 11:04 PM
Car Tweaker's Avatar
Default distributor problem
i have a b18 ls motor and i am throwing a check engine light for a bad distributor, so just to make sure it was the distibutor itself i tried replacing it with a friends and the cel went off, so i went to autozone to to purchase a IGNITER UNIT ASSY.# 8, and a COIL ASSY., IGNITION # 12, http://www.acuraoemparts.com/delray/...All&vinsrch=no
after replacing those parts i am still getting a cel even after resetting the ecu, does anyone know what the problem could be if its not either of those parts?
Old May 11, 2009 | 02:40 AM
Default Re: distributor problem
bump ?
Old May 11, 2009 | 03:01 AM
hondamark35's Avatar
you wouldn't throw a code for either of those parts having gone bad. when those go bad, your car will not start up. (in fact, if they go bad while your driving, the car will cut off in the middle of the road)
anyway, the CEL is probably for one of the two or three sensors inside the distributor. which code was it, 9?
Old May 11, 2009 | 06:04 AM
yup it was a code 9, could anything be replaced or do i need a whole new dizzy?
Old May 11, 2009 | 06:54 AM
Former User's Avatar
You need to replace the distributor housing, which contains the three distributor sensors.
Old May 11, 2009 | 07:26 AM
would that be the whole numebr 4?
Old May 12, 2009 | 05:08 PM
bump?
Old May 14, 2009 | 04:46 AM
bump
Old May 14, 2009 | 05:32 AM
Utzz's Avatar
Yes, #4 contains the part that is throwing your code.
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
mortificationrock
Mar 21, 2011 10:21 AM
civic91
Jan 23, 2010 07:12 AM
DVS Luder
Oct 16, 2006 01:39 AM
LilCivic04
Oct 14, 2005 09:19 AM
