cams for f22b1
How do you feel about me getting a stage 2 bisimoto cam with valvesprings & lifters?
There is also a stage 1.2 turbo cam available... would it be best to just wait and get the 1.2 turbo cam after i turbo, or get the stage 2 now and run that with the turbo later?
In other words, seeing as its called a "1.2 turbo cam" is that better for turbo than the "stage 2 cam" or what? They both cost the same for the grind.
Also, if I were to get the cam, what do you guys think about running an h22 trans for higher revving? And about tuning, I know the h series trans can bolt up to the F, but how much tuning would be necessary, would I be best off just getting a new ecu?
Anyways, I plan on getting headwork and all that **** as well.
CAM SPECS:
stage 1.2 turbo cam grind
0.396" valve lift on the intake and 0.410" exh; 220 deg duration on intake and 227 deg exhaust at 0.040"
Stage 2 cam:
0.410" valve lift on the intake and 0.370 exh; 230 deg duration on intake and exhaust at 0.040"
CAM SPECS:
Stage 2 cam:
