What's with this oil cooler?
Old May 10, 2009 | 07:44 PM
meanshyguy's Avatar
Default What's with this oil cooler?
I'm not sure but I think the guy who built my engine mentioned something about putting a different oil cooler on the block, maybe from a B series, these two outlets seem to go somewhere but I haven't had any oil leaks at all. Am I safe driving it the way it is?
Old May 10, 2009 | 08:13 PM
Hawkze_2.3's Avatar
Default Re: What's with this oil cooler?
Those are likely for coolant to flow into the cooler and exchange heat. If they're not hooked up it should be fine because there's nothing to leak, just an empty pathway.
Old May 10, 2009 | 08:37 PM
vinuneuro's Avatar
The oil filter base is acutally an oil cooler. Would be interesting to see how he's blocked off the inlet/outlet on the block and head. Buy the hoses from Honda and hook the oil cooler up. There's no reason not to. Frankly, I wouldn't go back to this guy if he did this.
Old May 10, 2009 | 08:53 PM
meanshyguy's Avatar
I'm hooking up an aftermarket oil cooling kit, and no, this guy won't ever touch my car.
Old May 11, 2009 | 04:15 AM
PirateMcFred's Avatar
Only thing I see that's wrong is the filter used there...
Old May 11, 2009 | 10:55 AM
meanshyguy's Avatar
^^ You're right, next time I'll buy the mobil 1.
Old May 11, 2009 | 11:25 PM
A_ALCHAAR's Avatar
I dont think there is anything wrong. Those iar for coolant inlet/outlet as mentioned before. He did not block off any oil passages. You just need to find a place to tap into the coolant to actually use that cooling feature. It looks very similar to the Acura legends (C32) oil cooler.
Old May 11, 2009 | 11:27 PM
A_ALCHAAR's Avatar
Maybe try blowing in one side and see if it comes right out the other to confirm.
Old May 12, 2009 | 08:15 AM
meanshyguy's Avatar
My plans are to install the aftermarket oil cooler, I was selling it but I decided to just keep it just to be a littler safer. Thanks guys!
92accordEX4life
Jan 17, 2006 05:30 PM
JDMTurboCivic11
Oct 26, 2004 07:18 AM
jdmcx
Apr 7, 2004 06:38 AM
People_Mover
May 19, 2003 01:05 PM
