Help 1993 Accord Clicking while turning left and sometimes right
Old May 10, 2009 | 07:28 PM
rodneylynn1977's Avatar
Default Help 1993 Accord Clicking while turning left and sometimes right
I replaced the left and right CV axle assembly but the car is still clicking mostly turning to the right...
Any ideas, The right axle was shot... did the left just because I had the car on the hoist!!!
Old May 10, 2009 | 07:58 PM
Geonerd's Avatar
Default Re: Help 1993 Accord Clicking while turning left and sometimes right
Put the car back on the hoist (unload the wheels) and check the lower ball joints for any sign of slop or play. If present, this is cause for immediate concern!
Remove tire and check the upper ball joint and upper control arm bushings (these often start to crack after 18+ years.
Check main spring for breaks - rare but not unheard of.
Are steering pushrod boots in good shape? No dirt in the rack and pinion area?
Old May 10, 2009 | 08:20 PM
jdmwannabee's Avatar
seems like he's covered the problem areas well.
Old May 10, 2009 | 08:27 PM
I will do those things next time I have the hoist available... They all sound pretty easy to replace. I have to do a pan gasket and front brake pads also!!!
Old May 10, 2009 | 10:27 PM
YeuEmMaiMai's Avatar
is everything torqued right?
Kogmachine
Jan 2, 2023 01:21 PM
ragnarok0mega
Jul 11, 2009 08:51 PM
Ltsmith05
Dec 6, 2006 04:35 PM
Pochtecatl
Jul 16, 2004 05:57 AM
91accordwagon
Apr 21, 2003 01:12 PM
