Can a stock ITR airbox fit into a 6th gen hatch w/B16A?
Old Aug 17, 2002 | 07:05 PM
skafia's Avatar
25 Year Member
Default Can a stock ITR airbox fit into a 6th gen hatch w/B16A?
As the question states... will it fit perfectly?
Old Aug 17, 2002 | 07:24 PM
Losrocket_'s Avatar
Default Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (skafia)
My friend has a B18C1 in his '97 CX hb and he has an ITR air box. It fits fine it just doesnt bolt in. He had to rig the mounts to secure it. I dont see why it wouldnt fit with a B16.
Old Aug 17, 2002 | 07:30 PM
skafia's Avatar
25 Year Member
Default Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (Seats Four)
Well... anybody else have any other experiences?
Old Aug 17, 2002 | 08:30 PM
Kengs's Avatar
Clearance wise, it should be OK; I say that because I am using an EK version of the ARC induction box in my '00 Si and it is larger than the ITR airbox.
[Modified by kengs, 12:30 AM 8/18/2002]
Old Aug 18, 2002 | 12:14 AM
joeseph's Avatar
Default Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (kengs)
anyone runing an integra (any trim level) air box in a 5th gen civic?
Old Aug 18, 2002 | 12:46 AM
IdotheSHOCKER's Avatar
Default Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (jcnfh)
Yeah. I have the same question.........
Old Aug 18, 2002 | 02:28 PM
joeseph's Avatar
Default Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (EGB18hatch)
anyone???
Old Aug 21, 2002 | 01:49 PM
skafia's Avatar
25 Year Member
ttt
Old Aug 21, 2002 | 01:56 PM
Doctor CorteZ's Avatar
Yep
Old Aug 21, 2002 | 02:06 PM
Cheap Bastard's Avatar
New User
It will fit, but you will need custome brackets for the air box. Hardware store pieces.
Old Aug 21, 2002 | 02:17 PM
joeseph's Avatar
Default Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (Doctor CorteZ)
Yep
could you elaborate,
regualar intergra box or type r, what sort of mounting bracketts? did the inlet tube and the hole in the fender match? did you retain the stock civic arm? any photographs?
thanks
Old Aug 21, 2002 | 02:32 PM
I'll take pics
I used a 94-up 3" short ram for a teg
94 LS box
K/N RU-2820 filter
custom bracket
heat wrap
I'll post a full write up when I get time
I can tell you this it is very nice and low key
Old Aug 21, 2002 | 02:34 PM
skafia's Avatar
25 Year Member
what.. .what about the AEM CAI ?
Old Aug 21, 2002 | 08:13 PM
New User
All DC2 air boxes are the same. The only difference is the tube. GSR bends lower, because of the t.b location. LS and ITR have approximately the same t.b. location. The main differences are tube id taper off more rapidly for LS tube. I think 2.5" and 3" respectively. Also there is a resonator before the outlet of the arm for the LS.
Either LS or ITR intake arms can be used for 6th gen civics. The only other problem is the temp sensor, DC2 do not have one on the intake arm. You can punch out a hole into the arm or use the valve cover return hole and send the valve cover return elsewhere. i.e. oill catch can
The inlet tube to the air box routes off the inside and wraps under to the front corner of the bumper, where the aem cai is located. It does not go through the aem cai hole/stock Civic airbox pickup.
Old Aug 21, 2002 | 08:18 PM
New User
If you don't have a LS or ITR intake arm, all 3" short intake for 6th gen Civics will work.
AEM CAI will not work because, it's only 2.5" and the outlet on the DC2 air filter is 3". Most short rams are 3". A cheap shortie will work. I have a Matrix intake arm which also works. $70 with generic filter.
Old Aug 22, 2002 | 04:05 AM
june's Avatar
Where did you get that and how much?
Old Aug 22, 2002 | 04:49 AM
crap.....
Old Aug 22, 2002 | 04:47 PM
skafia's Avatar
25 Year Member
Why the "crap?"
aown61
Apr 14, 2005 11:05 AM
JDMliu
Jan 20, 2003 02:22 AM
comptechgsr
May 12, 2002 02:06 AM
BITeR
Apr 15, 2002 01:01 PM
