vtec GOOD OR BAD for turbo?
Old Aug 17, 2002 | 06:57 PM
h22accordturbo's Avatar
Default vtec GOOD OR BAD for turbo?
opinions any1?
Old Aug 17, 2002 | 07:00 PM
Brandon's Avatar
Life is Suffering
Default Re: vtec GOOD OR BAD for turbo? (h22accordturbo)
SOHC VTEC=Good for turbo
DOHC VTEC=Bad for turbo
Razor's Avatar
sohc vtec isn't as bad as dohc vtec, the bad thing about vtec is that you will have increased chances of 'blow-by' or whatever its called. someone else will elaborate...
Old Aug 17, 2002 | 07:02 PM
Brandon's Avatar
Life is Suffering
Default Re: vtec GOOD OR BAD for turbo? (Razor)
Blowby is when there is high overlap and the boosted air and fuel pass through the combustion chamber, and the pressure is lost.
Old Aug 17, 2002 | 07:39 PM
AC Slater's Avatar
Default Re: vtec GOOD OR BAD for turbo? (F22turbo)
Its not a metter of good and bad, it a matter of what is better or worse. Your gonna see power and run some Mustangs off the road, but the question is, for how long? Like he said, an Integra LS is more likely to hold boost and not throw a bearing since it is a DOHC non vtec. But a GSR will respond better to boost, but since the higher compression piston, not to mention dohc vtec, its gonna blow a lot sooner.
Old Aug 17, 2002 | 08:26 PM
Nick H's Avatar
New User
Default Re: vtec GOOD OR BAD for turbo? (Bad SS)
higher compression pistons + forced induction= detonating
forget vtec if you are going with a turbo...it is just more to go wrong and **** up in the long run...
Old Aug 17, 2002 | 09:06 PM
KTeller8's Avatar
Default Re: vtec GOOD OR BAD for turbo? (nickh2k1)
vtec= paying more to lower internals i know
Old Aug 17, 2002 | 09:19 PM
Nick M's Avatar
this is all true with a lack of tuning. Proper fuel/igniton/air makes for a happy motor, regardless of compression. A higher compression engine is just harder to tune with the addition of forced induction. Regardless of tuning, it is easier to make power with lower compression and a turbo.
Old Aug 17, 2002 | 09:42 PM
ArchAngel Sabastian's Avatar
New User
Default Re: vtec GOOD OR BAD for turbo? (HondaSport)
good topic.
but.. if you were going to build a motor with no limitations unlimited resources and such and given the motors not daily driver would you still go non-vtec for turbo, or would the vtec motor make more power on a short term timeline.
Old Aug 17, 2002 | 11:17 PM
H23 Power's Avatar
actually race teams run like 12:1 compression with 30 psi of boost
its all about tuning
Old Aug 18, 2002 | 08:12 PM
Nick H's Avatar
New User
Default Re: vtec GOOD OR BAD for turbo? (F23 Power)
and they tear down the motor after every session at the track
Old Aug 19, 2002 | 03:40 AM
H23 Power's Avatar
yeah, but they're not detonating
Old Aug 19, 2002 | 04:24 AM
Brandon's Avatar
Life is Suffering
But the words daily driver dont exist to them.
Old Aug 19, 2002 | 09:41 AM
Default vtec GOOD OR BAD for turbo? (h22accordturbo)
daily driven is my ? lower compression is better 4 boost
pnoipj89
Nov 21, 2008 09:54 PM
b18c1srfun
Nov 25, 2005 10:05 AM
h22accordturbo
Aug 19, 2002 09:41 AM
Andrea_Aunie
May 26, 2002 08:17 PM
hondanacura4life
May 19, 2002 07:58 PM
