AC problems
Old May 10, 2009 | 05:30 PM
suzuki1211's Avatar
Default AC problems
I have a 00 4dr 4cyl accord ex. The AC has quit, the compressor does not cycle on and off.Is this low on freon(leak). Checked the fuse and it is good. Any ideas? Thanks for your help!!!
Old May 10, 2009 | 06:00 PM
Targa250R's Avatar
be professional
Default Re: AC problems
Low or empty refrigerant will shut the system down. Could also be a bad compressor.
Start out by checking the pressures in the system. Add refrigerant if needed, and put in leak detection dye along with it. DO NOT put any type of sealant in there.
Old May 11, 2009 | 01:36 AM
suzuki1211's Avatar
great advice, i'll try it, thanks
Old May 11, 2009 | 02:21 AM
YeuEmMaiMai's Avatar
over charge will also cause the system to fail to operate properly. the best thing to do is to place the system on a vaccum and then charge to the proper levels. If there is a leak they should charge the system up and then use a sniffer to find the leak or insert a florescent dye and then have you come back in a few days.
not likely the compressor has failed, more likely that the condensor has a leak in it and that is a $$$$ to fix
flanker
39
Mar 25, 2015 08:56 PM
LSteggyguy
Jul 3, 2014 08:30 AM
marqoid
10
Jun 28, 2013 04:41 PM
cfortman
Aug 5, 2004 09:08 PM
Trey
Jul 14, 2003 08:58 AM
