Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Cannot start my engine!! no because of the Battery! Help ! thanks sosososo much!
Old May 10, 2009 | 11:53 AM
boyce1118's Avatar
New User
Default Cannot start my engine!! no because of the Battery! Help ! thanks sosososo much!
its a civic 06 sedan
I parked my car as usual, and once i try to start it yesterday, the starter keep " kakakakakkaka" sound but no response from the engine! then i test the battery, it has 12.4 V with should be enough for start. also the electrics inside the car runs, but just a bit weired. for example, when i push the Panic on the key, it will not as loud as usual, and it becomes "Beep-----beep----------beep----------" but not "beep beep beep" which is usual.
and when i roll up the power window, it runs but it stop a second after it roll a bit up and stop a while and up a bit until to the top.
CAN ANYONE HeLP or expericened this before??
Thanks so much for any comment or advise!!!
Old May 10, 2009 | 02:22 PM
C-Walker.626's Avatar
Default Re: Cannot start my engine!! no because of the Battery! Help ! thanks sosososo much!
yea im having that problem too i had to had some1 push start my car.
Old May 10, 2009 | 02:57 PM
Targa250R's Avatar
be professional
12V doesn't really mean much if the battery can't generate enough amperage to crank the engine. If the battery is only making 100 amps @ 12 volts, it's not going to start.
Your battery is likely dead. Chances are that you left a door ajar or a map/dome light on.
Old May 10, 2009 | 03:42 PM
av911's Avatar
^^yeah that
Not sure if your car is still under warranty, but jump start and have the dealership replace it.
Old May 10, 2009 | 03:46 PM
DBAl's Avatar
battery is under warranty still
Old May 10, 2009 | 04:20 PM
av911's Avatar
How can you tell?
Old May 10, 2009 | 04:25 PM
OUT OF ORDER ROB's Avatar
similar to my problem. forgot to turn off my headlights and tried jumping my car wouldnt work. baught a new battery still wouldnt work. Green Key inthe cluster kept blinking. Immobilizer not reading. Crank crank crank start and shut right off. immobilizer got reset and wont read the key, i had to tow my 06 civic to the dealer and get the keys reprogrammed. Hopefully thats your problem. Cost me total of 210$ including battery cuz my car had more then 60k and wont cover he battery.
Old May 10, 2009 | 06:47 PM
boyce1118's Avatar
New User
thanks so much for you guys reply,
some of you said the battery probably dead, but y the power window, panic and even the
air condition still works?
and seems the computer cannot recognise the key as well....coz when i start the engine , the immobolizer light is on.
my car already 54k miles, so do anyone knows if its still under warrnat for such matter??
Old May 10, 2009 | 06:55 PM
Targa250R's Avatar
be professional
Because the battery has enough juice to barely run the window motor and blower motor but not enough to crank the starter which requires a LOT more amperage?
Did you even bother to try jump starting it or do you just want the car to sit around dead?
Is it on solid or is it blinking repeatedly?
Old May 10, 2009 | 07:24 PM
all the power worked in my car also. But when i crank it on it Shut right off in like 5 secs.
My immobilizer light was on an blinking, So i called tons of dealers most said they need to diagnose the problem but the dealer next to my house already knew what the problem was. to get the keys reprogrammed cuz the battery went dead and reset everything. it was a defect only on 2006 Civic. By Vin# only.
9tailsfox
21
Jun 14, 2011 05:29 AM
xander1100
Oct 18, 2009 07:56 PM
egtony
May 18, 2009 09:58 AM
NMElude97
Jan 30, 2004 01:50 PM
tan2
Nov 4, 2002 10:10 AM
