battery cut off switch
can anyone show me a pic of the mounted battery cut off switch i read the scca rule book but i would like to get a picture of how it should look 00 civic si
Good point,and it should be a 4 post switch to cut the alternator off as well.
Here is a 99Si dash
Here is a 99Si dash
messy(sorry) Home written one is how mine is,if you can read it....
Last edited by JW racing; May 11, 2009 at 02:27 PM. Reason: Attached my switch diagram
you can legally do it using only 2 posts also. After having 2 kill switches go bad on the "small" posts i stopped using them
here is kind of a crappy picture that i will try and illustrate.
I have the battery positive coming to the one big post and the on the other big post i have my alt+, starter+, ignition+,fuse panel+ coming out and going to their respective locations.
If you search around i am pretty sure there are a few 3 plus page threads discussing ways to wire a kill switch.
It isn't a big deal i have mine mounted in the center of the car too.
SCCA club is weird. It has to be within XX inches from the window, but you don't have to be able to use it strapped in..
SCCA pro requires it to be within XX inches of the window AND you have to be able to use it strapped in...
I don't think NASA has any limitations on the placement of it.
Mine's in the back corner of the passenger window, mounted on a gusset on the roll cage (I don't have any pics of it, I'll try to get one this week). I bought a bicycle brake cable and housing, and ran it from the switch to a handle velcro'd next to my parking brake handle. Corner workers can access it quite easily, and I can cut it while strapped in if I feel the need to (hope I never need to).
corect me if im wrong but i thought the thick power wire coming from the alt if touching the fuse box power wire would stay running without a battery if so how could a 2 post work with atl wire and fuse box on the same post
