Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Cams seals keep leaking???
Old May 10, 2009 | 05:57 AM
psegs80's Avatar
Default Cams seals keep leaking???
I have a OE JDM B18C Type R bottom end, a ported and milled 0.020" head with Toda Spec b Cams and after 5 laps of revving to 8600rpm, my cams seals behind the cam gears always leak...to much crank case pressure????
I have an Endyn breather system:
- Removed and blocked the OE little black canister behind the block so removed the OE PCV system
- Removed the passenger side Frosh plug and installed the Endyn Feed outlet which goes to the catch can.
- The return under the catch can is sent back to a T-Fitting in the above blocks feed line (like indacated in the diagram that you get with the Endyn system)
- The valve cover OE Cam breather outlet is sent to the catch can
Motor compression when cold is 235-240 across the cylinders????
Old May 10, 2009 | 07:39 PM
FlatBrokeHatch's Avatar
Default Re: Cams seals keep leaking???
Wrong section. Wish I had an answer though, I've never seen anyone have this problem before.
Old May 10, 2009 | 09:09 PM
smokin rubber's Avatar
are they new seals?
Old May 11, 2009 | 04:08 AM
Conan the Destroyer's Avatar
stupid question, but can we assume youre putting a bead of honda bond on them?
Old May 11, 2009 | 04:28 AM
psegs80's Avatar
Yep, new Honda Seals...I'm trying to find teflon ones?
I'm putting a little bit of Grey Sealler arround them?
I'm assuming it's to much crank case pressure???
Old May 11, 2009 | 07:48 AM
KIWI's Avatar
I had the very same problem a few years ago in my B20 Motor. Funnily enough I had an Endyne Breather System as well...
I ended up running two -10 breather lines from the Valve cover.
FWIW.
Kiwi
LSTurbo23
Oct 22, 2011 08:13 AM
tempsohc
13
Jan 11, 2011 06:12 PM
Elex
May 16, 2003 11:13 AM
LB CRX
May 31, 2002 10:29 PM
