Wastegate spring, anyway of measuring PSI??
Old May 10, 2009 | 03:50 AM
djnikko's Avatar
Default Wastegate spring, anyway of measuring PSI??
I have a couple of wastegate springs I bought a couple of years ago and am wanting to use them but I have no idea what PSI they are, is there a technical way of measuring this? I have searched the faq but couldnt see a topic relating to this. My guess is you'd put some weight on the spring and measure how much it contracts by. Can anyone help?
Thanks in advance
Old May 10, 2009 | 03:54 AM
djnikko's Avatar
Default Re: Wastegate spring, anyway of measuring PSI??
I found this for suspension springs
http://www.my-acoustic.com/Car/handl...ure_spring.htm
Im guessing its a simalar technique for other springs. If anyone has a homebrew method i'd love to know
Cheers
Old May 13, 2009 | 10:53 AM
WeeMan's Avatar
From: Put it in..Take it out... Put it in..Take it out, United States
If you have 38mm Tial...
http://www.tialmedia.com/documents/w3_tial_38_sp.pdf
Old May 13, 2009 | 11:03 AM
b20beast83's Avatar
they go by color
Old May 13, 2009 | 11:23 AM
Topdawgg's Avatar
Originally Posted by b20beast83
they go by color
Tial has a master list of every spring and every spring rating combo according to whichever Tial wastegate you have..
of course, this will vary depending on how much creep your setup has..
Why not just get a good Electronic boost controller, put a small spring in and use the controller to control the boost..
I have a small spring in mine and just use the Boost control with my S300. It keeps great boost levels.
Old May 13, 2009 | 01:55 PM
omgwtfbbq's Avatar
I had a wg that I didn't know what spring it had. I used a tire valve, 1/8npt fitting, hose and hose clamps. Connected it to a digital air chuck and tested it that way. Found out after a few tries that it's a 12 psi spring.
DOHC_16v
Aug 3, 2011 01:35 PM
95boostedeg
Jul 11, 2011 05:27 AM
chunkybs
Apr 13, 2008 08:17 AM
akira712
Aug 8, 2006 09:46 PM
LsTurbo91
Aug 14, 2001 04:36 PM
