23T mounting bracket on what model legend
I am planning on doing the legend 2pot caliper upgrade on my 98 civic ex but was wondering if only the gs has that bracket or did the lowere model legend also have that bracket. Reason I ask is I have seen a few legends at the yard but can't tell if they are gs or not(calipers already gone) but some still have the brackets. I am planning on buying rebuilt calipers anyway. Thanks in advance.
the single pistons are easier to setup. i have the same 23t conversion and it's a big upgrade from the stock gsr brakes. the two piston calipers are harder to bleed correctly since you have to mount them upside down. also, they have a leading and trailing piston. if i were you i would get the cheaper and easier to use single piston 23t. however, you can use rock auto to look at the different models and years to identify calipers. by the way, brackets come with rebuilt calipers, you're wasting your time getting brackets.
I didn't know they came with the rebuilt calipers, that's good to know. I remember seeing something about being able to use the single piston but never positive. Thanks
dayaftertomorrow
Acura TL, RL & ZDX
11
May 29, 2005 10:15 PM
