Lighting HID/Xenon kits, Retrofits and Associated Topics
Dont want to lose high beams.
Old May 9, 2009 | 11:44 PM
bsmith100's Avatar
Default Dont want to lose high beams.
I want to do an HID retrofit on an EK civic, except I don't want to lose the high beams, and I don't want to go with a bi-xenon setup either.
Has anyone tried a retrofit with some of those TYC projector style head lamps with the separate bulbs for the hi and low beams?
That way I could do the HID retrofit on the low beam projector, and leave the high beam alone.
Anybody have any opinions on the quality of the TYC head lamp units?
Old May 10, 2009 | 01:02 PM
djslim23's Avatar
Default Re: Dont want to lose high beams.
I'm in progress retrofitting a "quad-light" setup as you described. I used an old eBay projector housing on my EJ. Also, I have heard good things about the TYC lights. I can post up some pics when I'm done, it should be this week. I think I actually ran into more trouble with the mounting and the wiring than I would have using the stock housing, but I'm pretty sure I'll get a unique look.
Old May 10, 2009 | 05:10 PM
bsmith100's Avatar
That sounds really cool!
I can't wait to see the shots of your car and the of lights when you are done.
I was also thinking that the wiring would be the toughest part.
Did you have to build your own wiring harness?
Old May 12, 2009 | 09:06 AM
djslim23's Avatar
Sorry for the late reply...I actually used a harness I got off eBay which was designed for H4 bulbs (I used to have pnp's). I think that's why the wiring has been difficult. I'm basically done with everything appearance wise..just put a clear-coat on it all yesterday and added some finishing touches. Now all I have to do is get my brights functioning. I'll post some pics soon and keep you updated
Old May 14, 2009 | 07:39 PM
djslim23's Avatar
Ok so I should be alllll done tomorrow...I found out the wiring was so hard because my relays were messed up and my high beam bulbs were burnt out and i didnt know it!!
I should have some pics for you asap.
Old May 15, 2009 | 07:38 AM
sikmansherman's Avatar
I've been thinking about that for a whole month. I don't want to go bi-xenon because I wish to have my low beam stay on when I switch it to high-beam. I don't know what can I do with my 4D EG with a depo Clear glass headlamp.Is it possible to put a tiny fog-light inside the headlamp unit for the highbeam?
Old May 17, 2009 | 06:22 AM
djslim23's Avatar
Here use go, I'll post some pics w/ cutoff and **** in the Retrofit Club when I get a chance.
I am in the middle of doing body work w/ the bumper, fender and side skirts....so that's why it looks like crap and the lights don't really line up well.
Old May 17, 2009 | 10:50 AM
98civdx's Avatar
Master Detailer
retro looks good car looks horrible.
and did you put the eye lids in side the headlight??
Old May 17, 2009 | 04:31 PM
djslim23's Avatar
exactly why i noted that i'm in the middle of doing body work, and yes i put the eyelid inside. attached it to the lens w/ clear silicone
Old May 17, 2009 | 05:58 PM
98civdx's Avatar
Master Detailer
well they dont look bad, really different.
Old May 17, 2009 | 06:01 PM
djslim23's Avatar
thanks, thats what i was goin for
Old May 22, 2009 | 08:18 PM
bsmith100's Avatar
The lights turned out really nicely!
Old May 22, 2009 | 09:25 PM
djslim23's Avatar
Thanks a lot! I would post some pics of the cutoff, but it aint that great right now...the projectors I bought from a random guy on HIDplanet had dents in the bowls so there are some imperfections. Once I get that fixed I'll put up some finished pics in the club section.
98trooper
53
Jan 23, 2013 12:41 AM
x22xhyper
Nov 6, 2008 10:42 AM
turboman
Lighting
11
Jul 14, 2008 08:07 AM
AF-b16a1
Jul 26, 2004 05:24 PM
