rubbing noise only on left turns, please help?
Old Aug 17, 2002 | 05:22 PM
90-CRXSi's Avatar
Default rubbing noise only on left turns, please help?
It makes a rubbing noise on hard left turns that sounds like the tires are hitting but it dosn't do it on the right turns. I took it to a mechanic and they said it was the cv joints on the axles so I replaced those with 90 integra axles for the second time. On the new remanufactured axles the cv boot on the wheel side of the axle was very stiff and the transmission side was loose. Is this normal, the guy at Autozone said it was but I'm not sure he new what he was talking about. If you guys don't think it is the cv boots, anything else that it might be? Any help would be appreciated as I am leary to drive it with the knocking noise it makes when i turn. Thanks.
Old Aug 17, 2002 | 05:32 PM
Hcivic88's Avatar
Default Re: rubbing noise only on left turns, please help? (90-CRXSi)
how are the ball joints on that side.
i'd think it was the cv joint too, but it could be a ball joint or bushing. another thing you might want to check is your suspension, i've heard they can knock sometimes
sorry, cant really help ya unless i heard the knock and looked at the car myself, but those are a few suggestions.
does it only knock when your turning? just when your braking? accelerating? all the time?
Old Aug 17, 2002 | 05:42 PM
90-CRXSi's Avatar
Default Re: rubbing noise only on left turns, please help? (Hcivic88)
it does it whether i'm braking around a turn or accelerating. what part of the suspension do you think would be hitting. Anyone know if the cv joint on the wheel side of the axle is supposed to be a little stiff?
Old Aug 19, 2002 | 07:30 AM
90-CRXSi's Avatar
I don't want to spend money on a mechanic telling me its the cv boot if I've already replaced the cv axle shaft twice, but with faulty parts.
Old Aug 19, 2002 | 09:54 AM
88_SC_CRX_Si's Avatar
New User
Try pulling the tire(s) off, and seeing if there are any shiny places. That well tell you if your actually hitting something. Or there is something wrong with the CV...
Old Aug 19, 2002 | 10:43 AM
90-CRXSi's Avatar
Default Re: rubbing noise only on left turns, please help? (88_SC_CRX_Si)
i tried that and saw nothing, there are also no rub marks on the tires. Anyone know about the axles.
xiztence
Jul 13, 2007 04:25 AM
nonvtec92
16
Mar 23, 2007 01:28 PM
TunerShark
25
Nov 4, 2006 03:30 PM
lowRIDAH
12
Dec 27, 2004 09:05 AM
flip1199
Oct 24, 2002 10:58 AM
