94 b20b problem
Old May 9, 2009 | 09:14 PM
dorado_mike's Avatar
Default 94 b20b problem
Just got a chip installed in my Obd1 ecu and it works good until i run the car...The chip makes the b20b run really rich..when i step on the gas to get the car moving, it seems to drown in gas and wont take off right until it hits about 3k..if im running it and lightly step on the gas it backfires like a motha'. I orderd the chip with a b20b basemap. and there is no CEL.is there anything i can do to solve this problem? anything to do with timing? ..Is there a way to self tune these chips? Thanks honda-tech..
Old May 9, 2009 | 09:46 PM
Default Re: 94 b20b problem
bump
Old May 9, 2009 | 10:28 PM
sirt_eg's Avatar
check your spark plug and see if its running rich also check your timing see if its correct. you can self tune it but your going to need a program, just have someone else tune it for you.
Old May 10, 2009 | 08:12 PM
will try thanx
Josh1234
May 8, 2016 02:29 AM
chrisxmichael
10
Mar 25, 2011 10:53 AM
BLU CIVIC
Sep 17, 2007 08:13 PM
cleanda6
Sep 12, 2006 11:36 AM
VvPeachyvV
Mar 6, 2006 08:14 AM
