usdm pr4 crome pro code 36? WTF!
Old May 9, 2009 | 08:01 PM
sscivicsi's Avatar
Default usdm pr4 crome pro code 36? WTF!
usdm pr4 obd1 ecu with crome pro.
converted ecu to manual
boosted 1000cc injector map with gm 3bar
throws a code 36 ( yes i have checked it and all my friends have it IS code 36!)
code 36 is traction control froma jdm ecu, so I am stumped?
car will not stay at a decent rpm level without chopping out and acts as if i am turning the key off and on when i try to rev past 1000 rpm
sohc turbo
Old May 9, 2009 | 09:41 PM
HRTuning's Avatar
Default Re: usdm pr4 crome pro code 36? WTF!
That code won't cause the issue you're talking about. Sounds like you need to do more tuning.
Old May 10, 2009 | 05:47 AM
sscivicsi's Avatar
ok but regardless why is there a code 36? bad ecu?
Old May 10, 2009 | 09:15 AM
HRTuning's Avatar
No, a bad ECU would put you in limp mode. You're using crome and you chose a codebase that throws that code.
crxtreme27
Feb 4, 2004 10:19 PM
HondaCutie90
Feb 25, 2002 09:43 AM
boost killz
Sep 7, 2001 10:59 AM
