I think i blew my transmission? HELP ASAP PLEASE!
Old May 9, 2009 | 04:42 PM
FRKWOO's Avatar
Default I think i blew my transmission? HELP ASAP PLEASE!
today on the way home on the freeway was in 5th gear (00 ek hatch d16y8) clutched down to put back in neutral, clutch pedal sank to the floor no pressure? got off freeway and i turned off the car pumped the clutch and sunk to floor and didnt come back up then i started the car and tried putting in 1st gear wouldnt go in so i pressured it in and it went in drove home parked in garage jacked up the car noticed the seal where the motor and tranny meets was leaking (right under the headers downpipe) and oil splattered everywhere under. check the tranny oil on top of the motor infront of steering wheel no oil at all. did i blow my clutch or whats wrong with it and what do i need to do to fix it? thanks h-t!
Old May 9, 2009 | 04:58 PM
revhardallday's Avatar
Default Re: I think i blew my transmission? HELP ASAP PLEASE!
replace you slave cylinder no big deal its the part that pushes on the clutch fork when u step on the clutch.. replace it fill the clutch fluid resevoir and bleed the system and u will good to go
Old May 9, 2009 | 05:02 PM
thi3v3z's Avatar
You may not even need to replace, Your piston might have just slipped out. Check and see if the metal piston is still there, otherwise yea, replace the slave cylinder.
Old May 9, 2009 | 05:04 PM
FRKWOO's Avatar
Why is it leaking?
Old May 9, 2009 | 05:06 PM
1992Si's Avatar
Should be a $20.00 part at a auto parts store.
Old May 9, 2009 | 05:07 PM
thi3v3z's Avatar
The slave cylinder has a little metal piston that is surrounded by a rubber boot. If the piston comes out of the cylinder, the fluid can leak past it and run all over the place. The piston may have just slid out and nothings wrong. OR the seal may be bad on the slave cylinder and you need to replace. Either way, neither takes alot of time, or money.
Old May 9, 2009 | 05:08 PM
thi3v3z's Avatar
Just looked on autozone, new part is 13.99 Might as well replace it and be on the safe side.
Old May 9, 2009 | 05:10 PM
1992Si's Avatar
http://www.hondaautomotiveparts.com/...ASTER+CYLINDER
There's a picture for you.
Old May 9, 2009 | 05:30 PM
FRKWOO's Avatar
thanks for all the help guys
Old May 9, 2009 | 08:19 PM
Vindicator9000's Avatar
318 Curves, 11 miles
yeah it sounds like your slave cylinder. There's no fluid where your tranny and motor meet, it's completely dry there. If you're seeing fluid there, it's leaking from your slave cylinder.
Also, your clutch symptoms totally indicate lack of clutch fluid... which would be caused by your slave cylinder.
Old May 10, 2009 | 12:13 AM
RunninEg6's Avatar
make sure you isolate where the leak's coming from to make sure. don't wanna buy parts and still have a problem. same thing happened to me last month turned out to be the hard line to the slave cylinder had fluid going past the fitting.
Old May 10, 2009 | 07:16 AM
Pothole987's Avatar
also check the line for leaks around the area.
Crazed_GSR
Jun 3, 2013 11:07 PM
theslugbug
14
Jun 26, 2008 09:28 PM
boostede46
Jan 28, 2008 07:36 PM
OSG 97 ITR
Apr 17, 2004 10:11 AM
Kasper.
Jun 22, 2002 10:56 AM
