Need help wont rev past 3000 no code
Old May 9, 2009 | 02:39 PM
nnmewes's Avatar
New User
Default Need help wont rev past 3000 no code
Ok like the title said I have a D16Z6 that wont rev past 3000 and the idle is a little rough. I thought it was my TPS sensor (damaged during swap) I replaced it but no change anyone have any Ideas. I search on here and saw some one mention the distributor does any one know how I could test this.
Old May 9, 2009 | 03:18 PM
waaBAAH's Avatar
Default Re: Need help wont rev past 3000 no code
sounds like an ecu problem or possible vtec issue.
what kind of mods do you have on this motor?
Old May 9, 2009 | 03:46 PM
Meyerman015's Avatar
does the speedometer jump at all? If so, it could be Vehicle Speed Sensor. my buddies speedo jumped and he could not rev past a point, so he just replaced his VSS and it corrected the problem.
Old May 9, 2009 | 05:05 PM
revhardallday's Avatar
make sure the spark plug wires are in the right order... also disconnect the battery and hold the negative and positive cabels together for 2 mins and then reconnect it and start the car and rev it up.... this will reset the ecu
Old May 9, 2009 | 08:42 PM
nnmewes's Avatar
New User
A buddy of mine has another ECU going to swap that tomarrow yes the speedo does jump around I just picked up a VSS sensor at autozone going to install it tomarrow
To answer your question the motor is clean no mods yet.
If any one can think of any thing else I would appreciate it. I will let you all know if any of this helps.
Old May 9, 2009 | 09:18 PM
civic_driver's Avatar
Check timing. On the D16Z6 I think it should be 16 degrees BTDC.
Old May 10, 2009 | 12:00 AM
RunninEg6's Avatar
happened to me when i did my swap. wouldn't go past 3k but i had a code for my TDC sensor. it was shot so i replaced the distributor
Old May 10, 2009 | 09:03 AM
nnmewes's Avatar
New User
Ok not the VSS sensor replaced no help also disconected the cat and no help there either.
Old May 10, 2009 | 12:21 PM
nnmewes's Avatar
New User
Ok thanks for the help problem solved it tured out to be the cap and roter the set screw had come out and the roter had jamed at an angle and was not making good contact and on top of that oil had gotten inside and was mucking the place up.
Old May 10, 2009 | 12:39 PM
robbys89's Avatar
new cap and rotor it is then. happend to me before aswel. try getting some thread locker for that screw so you wont have to worry about that problem again anytime soon
Akdmks187
Jul 6, 2010 10:52 AM
Bejita
11
Jan 23, 2007 12:23 AM
winkelvtec
Feb 10, 2005 02:01 PM
DSRxMilogen
Oct 3, 2004 08:13 PM
msrrex
Nov 2, 2003 10:14 AM
