H22 in 95 ex coupe Help!!
i have done my swap and still trying to get my car driving. It runs but really weird the idle will bounce and when driving it seems to have no power at all can"t tell if it"s miss firing or what if anyone can help i would appreciate it.
check all your vacuum lines. and i also had no power when i did my swap. turns out i had the coolant temp sensor and another sensor switch cause their the same plug. the bouncing idle could also be a dirty iac on the front of the intake manifold, or a bad fast idle thermo valve located under the throttle body.
well the motor came with a external coil and my harness is set up for an internal so i got an internal coil distributor does anyone know if that will canse a problem
Well if i have a bad ground would it do the same thing? i have checked everything and i don't know what to do haha i feel like such a novice!!
