Which headgasket & headbolts do i use?
Old May 9, 2009 | 09:30 AM
1phatEG8's Avatar
Icon6 Which headgasket & headbolts do i use?
Okay, i have a friend who's got a 91' civic with a D16A6. He's putting a ZC head on it,
head code PM3-10. My question is, which bolts and gasket should he use? I think A6,
but just wanna make sure. Any input would really help. thanks
Old May 9, 2009 | 10:20 AM
88_acED6's Avatar
Default Re: Which headgasket & headbolts do i use?
use a z6 headgasket
Old May 9, 2009 | 11:59 AM
24TEN's Avatar
PHANTOM MENACE
Under the assumption your friend is installing an SOHC non VTEC ZC head (PM3 cast) he'd use the exact same gasket and bolts since it's going to an A6 block. As "88 acED6" stated, you can use a Z6 head gasket but you should make sure that the head and block are within spec because a stock Z6 head gasket is metal.
Off the wall question, is there any specific reason why your friend is doing this head swap? Because if I'm not mistaken, its the exact same head as the A6.
Old May 9, 2009 | 12:36 PM
1phatEG8's Avatar
That's what i figured. The reason my friend is changing his is bc he
overheated and cracked his old one. Thanks for all the help.
Old May 9, 2009 | 12:39 PM
Eighty-Nyne's Avatar
SOHC ZC head and A6 head are exactly the same except for cam.
Old May 9, 2009 | 08:50 PM
civicflow's Avatar
Make sure he checks the block for warpage...especially if he overheated the motor enough to crack the head.
Old May 11, 2009 | 02:12 PM
JOE BD-0's Avatar
Be sure to use the new style head bolts that have the spiral shaft. They are re-useable. The spiral shaft prevents stretching. Good Luck.
DrHorrorshow
Jul 12, 2014 08:59 AM
AlfieRoach
Jul 20, 2010 01:51 AM
prelude182
May 22, 2009 01:30 PM
mayfly
May 18, 2009 07:39 PM
slickrickauto
Aug 28, 2007 06:06 AM
