EF MPFI Help
Old May 9, 2009 | 12:46 AM
Asmooh's Avatar
Default EF MPFI Help
Hi all,
I searched the whole night for the MPFI swap.
And i saw that a lot of people doing this swap because its to easy.
But i also see that everyone swapping to obd1.
I can buy a D16Z6 intake with injectors.
But I still want to keep my OBD0.
can i use the Z6 injectors? or do I need A6/Z2 injectors?
And how about the ecu, i think the D15B2 ECU know he haves 4 injectors now and not two.
thanks a lot!
Old May 9, 2009 | 06:38 AM
89s1's Avatar
Default Re: EF MPFI Help
Yes, you can you the z6 injectors, just don't use a resistor box.
No, your d15b2 ecu doesn't know you have 4 injectors, you need a mpfi ecu
Old May 9, 2009 | 07:07 AM
Asmooh's Avatar
Thanks.
Which obd0 ecu is the best to use? 1.6 Z2/A6 ? or is there a better one.
Old May 9, 2009 | 11:30 AM
89s1's Avatar
Do a bit of research, you'll want an 88-91 si ecu.
Sounds like you haven't learned enough yet of thats a question you still need to ask.
88EFsedan2
Jan 13, 2012 02:57 PM
sleepercivic69
Sep 30, 2006 04:28 PM
Fusion G2 Civic
11
Jan 13, 2006 05:32 AM
Chris99SI
Jun 1, 2005 01:58 PM
