6th gen V6 and I4 rotors/caliper
Old Aug 17, 2002 | 03:34 PM
see_fu's Avatar
New User
Default 6th gen V6 and I4 rotors/caliper
I've been spending a great deal of time trying to find out if the v6 and I4 6th gen accords use the same caliper/rotors. I believe they use the same calipers even though the part number doesn't match. I know that the v6 is 5 lug so that's probably why the part number is different, but what i want to know is are the rotors on the v6 larger than the rotors on the I4. Specifically i'm interested in knowing if the v6 rotor is 11.2". I'm in the process of doing a legend caliper swap but i need to find out if the v6 accord uses a 11.2" rotor.
Old Aug 17, 2002 | 08:26 PM
H23 Power's Avatar
Default Re: 6th gen V6 and I4 rotors/caliper (see_fu)
yes, the v6 accord uses the 11.2" rotor
Old Aug 27, 2002 | 01:19 PM
jonj0n1's Avatar
Default Re: 6th gen V6 and I4 rotors/caliper (F23 Power)
is it possible to swap 6th gen v6 rotors on 6th gen 4 cyl and vise versa?
Old Aug 27, 2002 | 09:24 PM
WhoNeedsVtec's Avatar
Default Re: 6th gen V6 and I4 rotors/caliper (jonj0n1)
arent the 6th gen v6's 5 lug, and then 6th gen 4 cyl 4 lug?
Old Aug 27, 2002 | 09:30 PM
Brandon's Avatar
Life is Suffering
Default Re: 6th gen V6 and I4 rotors/caliper (WhoNeedsVtec)
You can swap in 5G discs and calipers.
Old Aug 28, 2002 | 07:29 AM
jonj0n1's Avatar
Default Re: 6th gen V6 and I4 rotors/caliper (F22turbo)
yup the v6 is 5 lugs and the 4cyl is 4 lugs. i like the new v6 coupe rims. try to fit it in my car.
KcAccord
Jul 23, 2017 01:55 PM
Mr.Speed
Oct 3, 2008 05:16 AM
LDYKLLA
Apr 29, 2004 01:45 PM
aburn
Jun 4, 2002 02:42 PM
TWG
May 23, 2002 11:16 AM
