s2000 with supra motor
as some of you guys know about this swap please let me no some info about it ...also i was thinking about boosting h22 in s2000 .....and i cant wait for the hondata ecu for the s2000 to come out ..its gonna be great any information on the ecu will be great from you guys
umm Hondata came out with the ECU for the S2k already. I run one, Hondata K-pro.
www.hondata.com go take a look.
and an H22 is a FWD motor, the S2k is a RWD car. To get it in there wouldn't be that big of a deal, but to find a tranny and diff that spins the opposite way would be difficult.
2JZ s2000's are simple, the front crossbeam is cut out and a 2jz is put in. only 2 steps to doing a 2jz swap. "1) Install the 2JZ motor, 2) wire it up"
Both swaps are a waste of money and you could have much more power out of the stock S2000 motor for much cheaper. Why would you ever think of putting in your S2000?
Im ready...
Im ready...
If you want to get an s2000 just to put another motor in it why are you even buying an s2000? Either turbo or s/c the s2k or buy something else. It'd be a hell of a lot cheaper
Seriously? H22 in a S2K? One of the finest Honda RWD car and throwing a crappy H22 onto it?
That's like Downgrading your B18C5 to a D16Y7.
You mine as well spend all that money converting your S2K into FWD and finding a tranny to make it 5speed again. Just invest it and find a way to put a C32B into that S2K.
For the most part you purchase an S2000 for the balance, precision, and power of the stock motor. The motor itself is pretty tuned from the factory which is why you can't find that many N/A parts for it that actually give you horsepower.
If you want a drag car, put the 2jz motor in and have fun, but don't try to corner like you once did with the F20 / F22 in there because you're going to spin out and crash... unless you run ridiculously wide tires in the rear.
I dont know what thread is worse this one or the camaro one
x2
f20/22c is based off the h22
