b16a2 on stock p28 o2 code?
Old May 8, 2009 | 06:03 PM
freakasis's Avatar
Default b16a2 on stock p28 o2 code?
i know im running the wrong maps on the ecu right now, but will this cause me to get an 02 code? i know the sensor is good and i checked the wiring all the back to the ecu, i get the cel 1 second after i start the car. is it because of the wrong maps? so it should go away once i get the ecu chipped with b16a2 maps?
thanks
Old May 8, 2009 | 07:10 PM
civic_driver's Avatar
Default Re: b16a2 on stock p28 o2 code?
No, having wrong maps won't cause an O2 code. Either the sensor is bad, the wiring, or the ECU.
Old May 8, 2009 | 07:29 PM
freakasis's Avatar
hmm...i hope its not the ecu, cuz the sensor was fine on my other motor and the wiring checks out. maybe the o2 got damaged somehow when i swapped motors. ill get a new one (its under warrenty) and see if the code goes away.
also i extended the o2 wires and the signal wire seemed to have some shielding on it, i didnt use a shielded wire when i extended it, is that gonna cause issues?
Old May 8, 2009 | 07:34 PM
How much did you extend them? I don't think it's a good idea to extend them by much as that will cause incorrect readings. Also, you should get a shielded wire as that will affect readings as well (due to interference if it's not shielded).
Old May 8, 2009 | 07:54 PM
freakasis's Avatar
about a foot, i am using a z6 harness, that had the o2 in the front of the motor, on a b16 that has the o2 in the rear of the downpipe.
also i noticed that honda only shielded the wire on the engine harness, when it goes through the shock tower plugs its no shielded anymore. thats why i figured it wouldnt make that big of a differance.
Old May 8, 2009 | 07:58 PM
freakasis's Avatar
the guy i got the motor from had it extended like 3 feet (from the front, over the trans and to the back) with extension cord wire and duct tape. i opened the harness up and soldered/heatshrinked brand new wire on there and reloomed everything. my way has to better right?
Vomit
Nov 20, 2013 08:24 PM
johnwohl
Mar 23, 2009 02:29 PM
95CivicGSR707
Apr 15, 2007 09:39 PM
denshu
Jan 11, 2004 07:46 AM
