25mm itr sway bar oem bushing
Front or rear? Cause what i listed above are the correct sizes for the rear sways from honda.
If your talking about the front sway bar, I've read from differnt places that it's either 24mm or 25mm so idk which size it really is. If it's really 25mm, What you can do is, get Part #3 from the link below. it will be 24mm. you can shave off 1mm from it and it will fit.
http://acuraautomotiveparts.org/acur...s=&view=normal
TurboBumblBee
Nov 6, 2003 07:05 AM
