2000 civic dx auto stalls
Old May 8, 2009 | 05:07 PM
MrRabbit87's Avatar
Default 2000 civic dx auto stalls
Ok so my friends 00 auto dx stalls under like stop and go traffic,
It will start to hesitate like its "coughing" and as i apply more gas to it dose not do anything.
I suspect an idle issues but seeing how it dose not pick up when I apply more gas to the car - I am stumped.
I am reading my service manual and I find that a weak fuel pump or clogged fuel filter may cause hesitation but I am not sure if it will cause it to stall.
for some help. No Codes too
I already checked the air filter, spark plug, oil, trans fluid, and coolant.
Old May 8, 2009 | 05:16 PM
thi3v3z's Avatar
Default Re: 2000 civic dx auto stalls
Sounds like a fuel filter, if it stalls even when you apply more fuel. A fuel filter is 20.00 at autozone and is never a bad decision to replace.
Old May 8, 2009 | 05:19 PM
MrRabbit87's Avatar
Yeah thats my next plan of attack, and if that dosent fix it i was going to check the impedance of the pump... any one know whats the stock ohms for the pump is?
Old May 8, 2009 | 06:21 PM
Former User's Avatar
Have you inspected the plug wires, distributor cap, and rotor? If those are fine, check the ignition timing with a timing gun.
Old May 8, 2009 | 06:32 PM
senser1080's Avatar
I suggest you replace both the fuel pump and filter. A buddies car had the same issue and I got a new pump at a junkyard for $50.
Old May 8, 2009 | 06:35 PM
thi3v3z's Avatar
Just try the fuel filter, then go from there. Guess and replace does very little besides take a big chunk out your wallet.
Old May 9, 2009 | 06:32 PM
MrRabbit87's Avatar
Thanks guys, I am going to replace the fuel filter and see how it goes from there. But do anybody know the resistance the fuel pump reads? This way i wouldn't have to guess on a semi-pricey thing like the pump.
I thought about the timing but i don't see how the timing would be off by so much for it to stall seeing its the original motor and all.
I'll look into the cap and rotors, but the spark wires look good, nothing frayed and i am not being electrocuted while i inspect it lol.
Old May 9, 2009 | 07:12 PM
Note that these symptoms are all consistent with problems with ignition system components and/or with the ignition timing. Such issues are very easy and inexpensive to check. In addition, ignition problems are much more common than are fuel problems, particularly a clogged fuel filter and a bad fuel pump.
Old May 10, 2009 | 12:49 PM
MrRabbit87's Avatar
alright i'll check it out how to diagnosis the ign system next. i'll post when i find the problem
Old May 10, 2009 | 01:02 PM
Targa250R's Avatar
be professional
Main relay.
It's never the fuel pump.
Old May 11, 2009 | 03:01 PM
MrRabbit87's Avatar
Well replaced the filter took like 5 minutes, easier than i thought. Car is running good, no signs of stalling after i tried to mimic traffic conditions by braking then tapping the gas lightly. Drove a few miles, seems like a fix.
As far as the main relay go i don't think its the main relay, i mean the car starts and usually a bad relay will stop the car from starting right? Thanks for the post though!
Old May 11, 2009 | 03:16 PM
thi3v3z's Avatar
So you replaced the fuel filter, and the problem is solved?
Old May 11, 2009 | 03:20 PM
Targa250R's Avatar
be professional
Not necessarily.
hgem1si
Aug 30, 2008 11:09 PM
ezol
Jun 15, 2007 03:40 PM
ezol
Apr 23, 2007 09:18 AM
lowered94accord
Mar 28, 2007 08:41 PM
TealCivic93
Feb 19, 2005 04:09 AM
