d15b7 and d16y7 timing degrees?
Old May 8, 2009 | 03:43 PM
builtsinglecam's Avatar
Default d15b7 and d16y7 timing degrees?
ok i want to know is with a stock d15b7 and a stock d16y7...what degrees is the timing supposed to be at because rite now my setup in my 98 civic is a d15b7 block with d16y7 head and i want to know if the timing changes when doing this setup or what degrees its supposed to be set at because my engine is kinda slow and sounds like a timing issue so help me out guys thanks.
Old May 8, 2009 | 06:22 PM
Default Re: d15b7 and d16y7 timing degrees?
anyone?
Old Oct 3, 2011 | 05:39 AM
Charlie Moua's Avatar
Old Oct 3, 2011 | 03:57 PM
ef_cowboy's Avatar
even tho is from the grave.... FROM WHat IVE READ if you put a y head on the b7 or z6 blocks your timing will be 4 degrees on the cam(depending) but if you shave the head more than 8 thousandths then it will fix that...i had a z6 block y8 head and i didnt have any timing issues.
Old Oct 3, 2011 | 03:59 PM
ef_cowboy's Avatar
im willing to bet you timing marks are off(behind the crank pulley)
nuclidex
Jul 22, 2014 02:03 AM
98h22
Jun 19, 2009 06:13 PM
petarr
Apr 7, 2006 10:11 PM
ncskate
Jun 15, 2005 07:23 PM
