used clutch
Old Aug 17, 2002 | 02:42 PM
CanadaCivic's Avatar
Default used clutch
i jusy bought a clutch that was used for about 3000 miles. Is it going to have an problems working in my car or will it be fine??? i heard it won't like getting used to a new flywheel. what if i get mine machined? Also i was wondering if it would be an ok idea to lighten my stock flywheel to say 14 lbs??? this is all on a b16 with s1 tranny btw.
Old Aug 17, 2002 | 03:06 PM
kyler's Avatar
Default Re: used clutch (CanadaCivic)
-the used clutch isnt ideal but it should work fine given the previous owner didn't abuse it too much
-14 lbs should be fine if the machine shop knows what they are doing, get it balanced afterwards and rough up the mating surface with some sandpaper to help the clutch bed better
Old Aug 18, 2002 | 09:06 AM
would it make a difference that it is a 6 puck with extreme pressure plate?? or does it match up all the same?
EDWINV00SI
24
Oct 13, 2011 06:08 PM
vishyncsu
Oct 7, 2004 10:38 AM
danny98r
Jun 24, 2004 12:15 PM
90-CRXSi
Oct 10, 2002 01:25 PM
matht27
Jul 16, 2002 04:34 AM
