Lug Nuts
Hi, would like to know if I could use thsi Vision lug nuts in my stock 99-00 Si rims. I have them installed in a blue 92 hatch, thanks
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
usually aftermarket lug nuts will fit, as long as they have the right size washer on them to keep the wheel on, best bet is to just take one off and test it on the wheel and make sure it doesn't go threw the hole
Usually the type of lug nut used has a built on washer u usually dont just add a washer cuzz the will throw off how tight the wheel gets to the hub, but if you are buying wheels from someone else and you hope your aftermarket lug nuts will fit just take one off and set it in a hole, or just buy factor lug nuts and you wont have a single problem
it's not recommended to run aftermarket lug nuts on OEM wheels.
look at the angle of how that Vision lugnut seats onto the rim. now look at your OEM lugnut. you'll notice that they're not the same.
prostreetonline
14
Apr 29, 2005 01:02 PM
prostreetonline
Sep 13, 2004 10:58 PM
Lei Siew Long
Aug 4, 2003 07:55 PM
