Jdm Front end???
Is it worth spending the money buying one? I know they look great but is it hard to put one on? I am gettin one for 700 with vis carbon fiber hood but i was jw if it was worth the hasel??? Thanks
$700 for an JDM ITR front end??? it must be made of fiberglass...... as far as installation, it also took me around 5-6hrs to complete it but if u dont know how to weld then i would strongly recommend taking it to a shop or person that can do this for u.
i agree with them...700 for a jdm front is a steal...most of the jdm front go for about 900 and up...if you have the money go for it the jdm front looks really nice.
Here in SoCal, it's like "Oh look, an Integra with a JDM front end...psssh whatever mine's nicer."
You need to jump on that, quick. I did mine by myself and it was easy. It took me longer than others because I was using a cordless drill to drill out the welds and the batteries would die after every spot weld.
Do you have the link to the DIY JDM installation? Very straight forward and easy to understand.
i did mine in 6 hrs including wiring.. its really worth doing .. so go for it..Oh and if u decide to do it ur self make sure u use spot weld bit and u can purchase them at a local like napa probably kragen.. good luck
