1987 honda accord 400.00 obo
Old May 8, 2009 | 02:08 AM
BoBaFreak's Avatar
Default 1987 honda accord 400.00 obo
SOLD SOLD and the problem was fixed!! Damn i think i sold the cheapest working car in ht history. WITH AC!
So today is my day i say enough with old cars. Working on this car today and i did the front brakes and new valve cover after driving it today. Everything was fine until i notice the lights on the car were dim and so were the interior lights right then and there i remembered i forgot to connect the ground wire back to the valve cover. So i turned off the car connected the ground and now the car wont start. I searched apon this and found out it was the main relay. Personally im done fixing old **** especially something like a main relay on this car which is way in the dash. no thanks. So that being said i pass this on to someone else. The car runs strong and it recently passed the smog besides the idle was too high(1300) in park. Ac blows super cold. Like i said i drove this car all day today and had no problems. Until now. So im going to man up and take the car payment and buy a fit. Heres the stats below.
*update* may 8, 2009 Car started. Definitely the main relay. ;(
*another update* 12:45pm just got back from the shop. Car needs a throttle body cable or you can fix this one and thats it.
Its a 1987 honda civic lxi *clean title*
Power windows power doors
Sunroof
Ice cold ac and power steering, working heater
Car recently passed smog except it needs the idle adjusted to be lower
Stock radio with working power antenna and the interior I say is a 8 out of 10.
the Body of the car is a 8 out of 10 due to paint. about to small half dime size dents on the hood.
The car has been well kept up with. The original manual and everything. I drove this car to la and back from mira loma 3 times with 25.00 on the tank.
Now the bad.
The paint its the original grey color but its going away
The main relay needs to be replaced which you can buy from autozone. Because of the hot weather the main relay since its the original one from the car when its hot inside the car when its been sitting out in the baking sun will cause the car not to start. You would have to roll down the windows for about 5 min let it cool inside the car and it'll start. This only occurs once out of a full day usually when I go to work around 11am and I have had the windows rolled up and its super baking from the inside. I get off work in the later afternoon I just turn the key and it doesent do it because its cool inside. Weird yes I know but once you replace the relay you won't have to do that and the car will start. This is a known common problem with the 3g accords after ages of use.
200.00 takes it im over it now.
Old May 8, 2009 | 03:02 AM
frontwheelfanatic's Avatar
Default Re: 1987 honda accord 400.00 obo
when did you get a 3g accord???
Old May 8, 2009 | 05:30 AM
BoBaFreak's Avatar
a week ago?
Old May 8, 2009 | 06:07 AM
BoBaFreak's Avatar
Car started this morning like nothing ever happened.
Old May 8, 2009 | 11:46 AM
BoBaFreak's Avatar
200.00 so it can make space for the new car!!
Old May 8, 2009 | 12:00 PM
ferio_boy's Avatar
lol... ttt
Old May 8, 2009 | 12:18 PM
DAb20vtec's Avatar
is there anyone you can deliver this biatch ? if not PM me so we can exchange numbers.
Old May 8, 2009 | 12:32 PM
BoBaFreak's Avatar
i can drive the car to you if your not far. I have aaa for 100 miles as well. Where you located?
Old May 8, 2009 | 01:14 PM
DAb20vtec's Avatar
pm'd!
Old May 8, 2009 | 01:51 PM
BoBaFreak's Avatar
photos up!
Old May 8, 2009 | 04:31 PM
you bought crystals old car
that's my spare tire on the driver rear
also i'm tempted to buy it
Old May 8, 2009 | 04:34 PM
BoBaFreak's Avatar
yes i did. now the new car needs room. If i can just replace the cable it would be good to go. I got a call from rock honda. I got approved so now i need a ride there. Care to take me ?
Old May 8, 2009 | 04:40 PM
whitecivic11's Avatar
pmed you
Old May 8, 2009 | 07:16 PM
BoBaFreak's Avatar
pmd back damn my inbox is crazy flooded! Just woke up
Old May 8, 2009 | 09:47 PM
BoBaFreak's Avatar
Sold!
Krandor
May 3, 2018 01:09 AM
BlackKimera
Honda CR-V & Element
May 1, 2016 11:49 AM
QuickSilverZ
May 17, 2013 05:49 AM
BoostinEJ1
Sep 1, 2010 11:45 AM
jiten42
Jul 4, 2003 07:34 AM
