Rims trouble plz help!!!
Old May 7, 2009 | 08:51 PM
SquirtleSquadEf9's Avatar
Default Rims trouble plz help!!!
hey wats up, i bought these two rims for my EF9, i put them on and they over gap the wheel hub. on the inside of the rim it says 4x100 and under it, is says 4x114. the rims mount and everything but it feels like there wiggling or something like if the rim isnt centered with the disc. the rims are not damaged. rims are 15in inside says 4x100 right under it says 4x114 tire size is 205/50....i took them off and put back the integra special edition rims which are 15in 4x100 and the tires are 205/60 and i have no problems with theses. so wat im wondering is if the 4x114 under the 4x100 have something to do wit the problem. any advise will be appreciated thanks....
Old May 7, 2009 | 08:56 PM
clovis88crx's Avatar
Default Re: Rims trouble plz help!!!
4x114 and 4x100 are totally different. they will not line up to each other. not sure what that means.
Old May 7, 2009 | 09:03 PM
the rims mount my stock civic. but like i said the center of the rim is bigger than the wheel hub could that be the problem??
Old May 7, 2009 | 09:28 PM
90_EX_Civic's Avatar
got a pic of the rims?
but, getting from what you are saying you need a hub spacer (think that's what it's called ). it's a small ring that fits over your hub to make your hub bigger. which would then center the rim and stop it from wiggling .
Old May 7, 2009 | 09:35 PM
ill try and take one now......ooohhhh s**t that sounds right... about how much are those spacers??? i just need 2...
Old May 7, 2009 | 09:46 PM
~sp33~'s Avatar
EFB055
Check ebay, they're not that much.
Old May 7, 2009 | 09:55 PM
ok i looked up some spacers...ive never had spacers before. this is my question now. how do the spacers make up for the empty space between the wheel hub and the rim??? if the makes any sense how i worded it.....
Old May 7, 2009 | 09:59 PM
see that's the only thing too. it's not a one size fits all type of thing. you gotta make sure that it fits snug, and that it's not to big.
and you're looking at the wrong type of spacer.
just looked, you something like this;
http://www.justforwheels.com/index.j...=how&track=GHR
Old May 7, 2009 | 10:02 PM
donut.'s Avatar
they're called hubcentric rings not spacers. first you need to measure the OD of your hub and the the inner diameter of the wheels to know which rings you need. Or just take your car/wheels to a tireshop and they should find something
Old May 7, 2009 | 10:03 PM
o ok ok the hub centric rings make more sense now. i need some of those =] thanks for the help. OK OK OK LAST QUESTION FOR REAL HAHA. how do i figure out what size i need???
Old May 7, 2009 | 10:11 PM
donut.'s Avatar
Maybe a measuring tool.
Old May 7, 2009 | 10:27 PM
?? wat kinda tool?
Old May 7, 2009 | 10:36 PM
donut.'s Avatar
Measure it with the lines on your finger
Old May 7, 2009 | 10:48 PM
is that a joke?? and how am i suppose to tell the person wat size i need
Old May 7, 2009 | 11:28 PM
~sp33~'s Avatar
EFB055
A ruler? C'mon man...
Old May 8, 2009 | 12:03 AM
88_acED6's Avatar
caliper
Old May 8, 2009 | 05:08 AM
johnnyonth3spot's Avatar
Originally Posted by SquirtleSquadEf9
?? wat kinda tool?
Come on man stop post whoring and wasting our time you ask to many questions why not try thinking for yourself or mabey actually searching
Old May 8, 2009 | 05:21 AM
Tomtheman70's Avatar
Ahhahaha.
Good ol morning laugh.
Old May 8, 2009 | 07:31 AM
dude if ur not going to help GTFO!!! johnnyouthspot!
Old May 8, 2009 | 01:34 PM
~sp33~'s Avatar
EFB055
If your not going to use your brain GTFO
Old May 9, 2009 | 04:51 PM
i found the ones that fit my car they were 2 for 10 bucks thanks guys
adriano7910
Sep 7, 2018 09:45 PM
low_and_slow
Apr 25, 2010 08:51 AM
slammeda
17
Feb 10, 2010 09:06 AM
6speed-ferio
Feb 26, 2009 05:57 PM
EMphaticONE
Jan 22, 2005 05:38 PM
