d16y8 in all EX models
Old May 7, 2009 | 08:24 PM
96CIVICEX's Avatar
Default d16y8 in all EX models
Im not sure if this is the right place for this question, so sorry in advance if its not. I was just wondering if all post 92 civic EX models come stock with a d16y8? Thanks
Old May 7, 2009 | 08:30 PM
ej6.sean's Avatar
Default Re: d16y8 in all EX models
92-95 ex/si d16z6
96-00 ex d16y8
Old May 7, 2009 | 08:36 PM
Unseen Racer's Avatar
Originally Posted by ej6.sean
92-95 ex/si d16z6
96-00 ex d16y8
Old May 7, 2009 | 08:37 PM
96CIVICEX's Avatar
92-95 ex/si d16z6
96-00 ex d16y8
both are sohc vtec though, right?
Old May 7, 2009 | 08:44 PM
shane7213's Avatar
Yes sir they are, I have the D16Z6 in my 94 EX.
Old May 7, 2009 | 08:51 PM
correct.
the y8 has SLIGHTLY more hp than the z6.
both are nearly identical other than a few slight changes
Old May 7, 2009 | 09:08 PM
ej6.sean's Avatar
z6's like boost and run hard for a single
chirp 2nd all day
Old May 8, 2009 | 07:15 AM
chirp 2nd all day
both z6 and the y8 like boost because of its pretty low compression
and i chirp 2nd and 3rd on my y8
Old May 8, 2009 | 07:58 AM
96CIVICEX's Avatar
So does it say vtec on the head? or where do I look to see if it says d16y8?
Old May 8, 2009 | 08:12 AM
the only one that says VTEC on the valve cover is the z6.
but you can use the valve cover from a z6 and put it on a y8
perfect fit
EDIT: like i have a y8 and i replaced the HONDA valve cover with the VTEC valve cover
Old May 8, 2009 | 09:13 AM
fc3srx729's Avatar
The Y8 doesn't feel like it has V-Tak at all...
Old May 8, 2009 | 09:18 AM
96CIVICEX's Avatar
Where do i look to make sure that the engine says d16y8?
Old May 8, 2009 | 09:26 AM
on your engine. where the tranny connects to your engine there will be a small flat piece of metal.
it will tell you your engine
i love my art work
ajason24
19
Aug 18, 2013 07:40 AM
96sloan
14
Feb 16, 2010 05:16 AM
User 12720
Jul 21, 2006 10:25 AM
allmotorEG-SI
15
May 24, 2004 09:11 PM
SOHC_DK.
Feb 6, 2003 06:47 AM
