good mechanic in NJ area?
Old May 7, 2009 | 07:50 PM
omerzam1's Avatar
Icon6 good mechanic in NJ area?
I need some motor work done on my b16 em1, tested compression myself 200 180 200 200, when i pulled out the plugs the second cylinder looked as though it had burned a little oil in it, sort of a yellowish tint to it(this was the 1 with slightly lower compression), but it's burning and smoking quite a bit of oil especially in vtec, assuming this has something having to do with the valves or valve guide seals, probably not piston rings judging from the compression test. Anyone know a good spot/someone who is trusted/does a good job? I'm in North Jersey Essex County, thanks. Might even wanna get the head redone if it's the right price.
Old May 8, 2009 | 08:31 AM
hondah2b21's Avatar
Default Re: good mechanic in NJ area?
you could check out topsecret located 150 east kinney in newark.
MB racing in garfield
CLM in newark
these guys are all good.
turbo-crx
Oct 10, 2007 09:29 AM
climb_on
Aug 4, 2007 07:14 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
Soled Out
Sep 9, 2003 05:08 AM
gsr stuie
Apr 23, 2002 08:03 PM
