honda b16a idles at 200 rpms and on the cluster gauge turns on
Old May 7, 2009 | 07:46 PM
EGR95's Avatar
Default honda b16a idles at 200 rpms and on the cluster gauge turns on
i bought a b16a 4 months ago and when i did the swap it starts up at 2000 rpms and the cluster gauge says that the motor needs oil but i checked the oil dipsticks it didnt need oil and i left it on 4 about 2 mins and it started to overheat if any 1 has a solution for this situation hook me up wit a diagram or pictures of the motor to solve try my problem
ps as soon as get this dun ill post up a vid of me racing
Old May 7, 2009 | 07:51 PM
civic_driver's Avatar
Default Re: honda b16a idles at 200 rpms and on the cluster gauge turns on
Doesn't the b16a require a larger radiator than the stock EG one? Also, I think that the oil light tells you that the oil pressure is too high (again, I think this is it, someone correct me if I'm wrong).
Old May 7, 2009 | 08:03 PM
z6hatchboy's Avatar
check the oil pressure sensor, and thermostat
Old May 7, 2009 | 08:04 PM
z6hatchboy's Avatar
the oil light warns thats its too low, as in a case that you may be low or have no oil (pressure that is)
Old May 7, 2009 | 08:08 PM
forcefedferio's Avatar
Old May 7, 2009 | 08:25 PM
It might show low oil pressure, not sure. But the oil pump is responsible for the oil pressure and if the oil pressure sensor is not damaged then it's a serious issue with the oil pump or motor.
Old May 7, 2009 | 08:26 PM
ej6.sean's Avatar
Old May 7, 2009 | 08:27 PM
lol, never seen this one
Old May 7, 2009 | 09:25 PM
gotz2b16's Avatar
Oil pressure sensor switches to ground when less than 5 psi of pressure is present. if your light is on, it's cause you have no oil pressure.. the likelyhood that your switch is grounded out is possible, but not at all likely.. probably just a shorted wire.. Because I tell ya what.. If you had less than 5 psi for long enough to overheat at 2k rpm, I wanna know what the hell you got for bearings!! Unobtanium??
As for the overheating, bleed your cooling system using a bleeder.. Make sure your EFFING thermostat is in correctly, and YES, B16's DID come with a larger radiator, but I promise you a D15B7 radiator will work fine unless you plan on convincing me that you're runnin 300hp shot of giggle juice at 2k rpm with no load..
Crackhead
Old May 8, 2009 | 04:24 AM
joelmatt89's Avatar
guys lets help him out as quick as we can that sounds sweeeet ha lol
this shouldn't be too hard, go to harbor freight fork over $10 for their oil pressure gauge and test your oil pressure I am not sure where it should be for each rpms, i do know it should be 60psi @ 5500rpms, but you could google to get the specs for other rpms. If it it overheating, your oil is not low, and the oil light is on then i would say you probably have low pressure. It is unlikely that the sensor would fail, however like someone did say the wiring could very easily gone bad if it got grounded somewhere.
Old May 25, 2009 | 01:14 PM
EGR95's Avatar
well i did found out that oil pump doesn't work and as far as the thermo i need to replace it and see if the motor doesn't overheat. maybe because the motor is made of titanium. but that doesn't matter. or what do u ppl think.
and for all u Bob Marley fans don't get caught... lol
Old May 25, 2009 | 07:46 PM
yes! leave the oil pump alone, change the thermostat and get your racing videos up STAT!
If new ****-fied H-T would allow me more than 3 lines of a signature, the bolded magical statement you made would be there.
BTW, bob marley and his music suck. just sayin.
Old May 25, 2009 | 09:38 PM
EGR95's Avatar
its all good.... some people are telling me that it could be the oil pickup and it could be one of the problems instead of the oil pump.
Old May 26, 2009 | 09:24 AM
if you are having oiling problems that may be it, how did you determine the oil pump is bad by the way? i would hate to see you start tearing things apart if it's only the sensor or something dumb.
Old May 26, 2009 | 06:41 PM
EGR95's Avatar
true... ok today what i did was i checked the oil pickup just to see if it was clogged, but it wasn't, so what I'm going to do is change the sensor to see if thats the problem, but can i replace it with the d15b sensor, and would it work?
Old May 26, 2009 | 08:08 PM
ok, i'm 99% sure they will be interchangeable, i've never personally done it so i can't be 100%. hopefully that's it and not the oil pump, also be sure to check wiring, if you have the insulation rubbed off a wire it may cause an intermittent light, or the light to be on all the time.
Old May 26, 2009 | 08:41 PM
EGR95's Avatar
well... let me see what happens, if its not the sensor then ill change the oil pump.
Old May 26, 2009 | 09:06 PM
Stine's Avatar
Grab a mechanical oil pressure guage, its the only way to be 100% sure.
Old May 26, 2009 | 09:30 PM
EGR95's Avatar
where can i buy the mech oil gauge?
CRXB5
Sep 26, 2010 04:12 PM
bradennicely
Mar 29, 2010 09:42 AM
lilshady6796
Oct 19, 2009 01:34 PM
iperez
May 10, 2007 06:41 PM
90hbvtec
Nov 17, 2003 06:13 PM
