New Exhaust Setup
Old May 7, 2009 | 05:34 PM
redline760's Avatar
Default New Exhaust Setup
I am thinking of ditching my dc sports header and greddy catback. I am thinking of getting 2.5 kteller piping a jdm itr header and a es tuning oval.
My question
1. Has anyone tried this setup
2. Will this be way too loud
3. Should i go with a hi flo cat or a test pipe.
Thanks.
Old May 7, 2009 | 08:09 PM
hickle's Avatar
Default Re: New Exhaust Setup
3. depends, do you want it to stay street legal? do you have to pass any sort of inspections? if the answer is "yes" to either of these, go with the high flow cat. also, if youre concerned about noise, a cat would probably be a bit quieter also.
Old May 7, 2009 | 08:54 PM
Hydro_Da's Avatar
add a resonator if your set up is too loud.
Old May 7, 2009 | 09:00 PM
uses0ap's Avatar
2.5in straight pipe FTW
Old May 7, 2009 | 09:05 PM
redline760's Avatar
whats a good resonator.
Old May 7, 2009 | 09:14 PM
Hydro_Da's Avatar
magnaflow makes some nice res.
Old May 7, 2009 | 09:37 PM
jdm_bones's Avatar
Very good choice, you will see a # difference if tuned...I say you add a Hi flow cat, because you are in cali, and we all know how that is...also try it out without RES first, then if its to much for you add the RES....I don't think it's that loud...but that just me...I am running a Profab 4-1 header 2.5"to a 2.5" high flow cat and a custom 2.5" pipe on a 2.5" es oval. And I made good numbers tuned at do it dyno!
Old May 7, 2009 | 09:46 PM
donut.'s Avatar
1. Probably
2. Everyones opinions on how an exhaust sounds or if it's loud is different. You'll have to goto a meet and check different exhausts out and have the owner rev it for you to form your own opinion.
3. If you really want the extra .25 whp and a chance of an expensive ticket
Old May 8, 2009 | 04:33 PM
redline760's Avatar
hey jdm bones how does your exhaust sound.
eastbobdam
Welding / Fabrication
Jul 6, 2009 04:42 AM
honda95civic
Aug 28, 2005 05:31 PM
Qwikrex
Feb 16, 2003 03:15 PM
SC0TT
11
Nov 8, 2002 08:27 PM
TSAngry
Nov 5, 2002 05:35 PM
