WTF dripping coolant from no where.
Old May 7, 2009 | 12:37 PM
Eighty-Nyne's Avatar
Default WTF dripping coolant from no where.
After I drive for about 6 minutes and then come and park my car.
If I look under my car I get a very fast drip of coolant on to my exhaust directly before my catalytic converter.
The drip slowly slows its rate until it stops.
I have gotten under the car and looked at every freaking hose. They are all dry and the leak is coming somewhere above my left axle...all gaskets and things look fine...
UGH
Old May 7, 2009 | 12:42 PM
DoubleEx's Avatar
Default Re: WTF dripping coolant from no where.
water pump is the only thing on that side.
Old May 7, 2009 | 12:47 PM
garageEF's Avatar
thermo switch for the fan is in that area as well.
Old May 7, 2009 | 12:48 PM
Its more towards the middle of my bay. Like directly where the left axle goes into my trans. It's dripping on that polyurethane coupling boot thing.
Old May 7, 2009 | 12:50 PM
DoubleEx's Avatar
hmmmm not sure then. Get it pressure checked.
Old May 7, 2009 | 12:51 PM
cpl rampage's Avatar
intake manifold, and TB both have coolant running through them, plus the lines to your heater core are right above there too.
0ne-Cam's Avatar
check the bolts on the t housing and check all the hoses going to the intake mani
Old May 7, 2009 | 01:02 PM
9KRevLimitDC2's Avatar
Did you check the hoses going into the IAC Valve and TB? Im trying to picture what would be directly above your header.. GL
Old May 7, 2009 | 01:08 PM
jlicrx's Avatar
the water pipe that runs from the water pump to the thermostat housing is also there - has o-rings each end that can sometimes leak
Old May 7, 2009 | 02:27 PM
Found the leak...took off the coolant line and there was one small pin hole on the TOP connection. But that wasn't the one leaking. Closer inspection makes me believe the seal around the base of the metal tube here is worn and coolant is getting by it. I don't think the coolant line itself is leaking. Can I just JB weld around the base of this metal thing? Or if not...what can I use to seal the base...
Old May 7, 2009 | 02:34 PM
crash232's Avatar
Ya, my radiator had the same issue due to it being old and shitty... There is stuff made specifically for high temperature and moisture I believe its called waterweld.... Ive used it on my radiator like 6 months ago and I havn't had an issue with it.
Old May 7, 2009 | 02:40 PM
Originally Posted by crash232
ya, my radiator had the same issue due to it being old and shitty... There is stuff made specifically for high temperature and moisture i believe its called waterweld.... Ive used it on my radiator like 6 months ago and i havn't had an issue with it.
thanks!
Old May 7, 2009 | 02:50 PM
DoubleEx's Avatar
Don't use anything that goes in your coolant to seal leaks. It can gum up other parts of your system and with a Honda you don't want to take chances on the w.p. getting fried. You can try jb weld it works wonders sometimes. Id hunt around for another piece in the mean time.
Old May 7, 2009 | 03:22 PM
I'm going for the directly applied approach...
Old May 7, 2009 | 06:58 PM
KWayRacing's Avatar
It sounds like one of the hoses coming off of the water pipe. Probably is the smaller one. MAybe you clould use a small mirror to look at the underside while it is dripping Or felx those hoses while the car is still hot but be careful for hot coolant in the eye could really suck.
Old May 7, 2009 | 07:38 PM
New hose and water weld worked perfect.
Old May 7, 2009 | 07:40 PM
jhammond_82's Avatar
Reject Papi
good deal.
turboman2.2
Aug 1, 2011 03:55 AM
lilmarcEH3
10
May 11, 2010 10:16 PM
blumpfish
15
Jul 4, 2006 02:11 AM
stupidwhitecat
Jul 3, 2006 05:20 PM
GetawayInMoscow
11
Apr 19, 2006 11:26 AM
